DSP Xover project (part 2) - Page 148 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st October 2013, 09:56 PM   #1471
chaparK is offline chaparK  Luxembourg
Originally Posted by Ryssen View Post
Cant`connect with WAF - Wroclaw Audio Force BAD GATEWAY..
Yes, this can happen once in a while. That's a hick-up at the hosting provider, I just checked now and the website is fine. Sorry for the inconvenience.
Originally Posted by Pascal GUERIN View Post
Hi Nick, wahouh v1.0.0 super
Yup that's a milestone, isn't it?
Alright, here's the list of upgrades that I have in my notes.
1. Allow enabling/disabling processing channels in order to save resources when the user needs less than 10 outputs.
2. Channel pairing/linking: what you change for one channel will also affect the paired channel.
3. New setup: FIR/IIR mix.
4. Allow renaming of sources (LCD).
5. Implement support for expansion board.
6. Decimation in FIR.
7. Support for external master clock.
8. Keyboard shortcuts for volume change when connected.
9. Include input response in output graph.
10. Check what's going on with Bass/Treble (clip led and phase)
That's a hell lot of work, so we need to prioritize tasks if we want to see a release soon (I want).
Discussion is open
Best,
Nick
Najda DSP
Old 1st October 2013, 10:03 PM   #1472
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
All but 3 and 6 is my choice... but I might need them later on..
Regards Åke
Old 2nd October 2013, 01:35 AM   #1473
Ryssen's Avatar
Have one connected to the expansion port right now..
Thought it was supported..
Regards Åke
Old 2nd October 2013, 02:24 AM   #1474
Shaun is offline Shaun  South Africa
Shaun's Avatar
Hi Nick
Please also consider adding user configurability for LCD (HD44780) vs OLED (WS0010) modules.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 2nd October 2013, 07:10 AM   #1475
mvaldes is offline mvaldes  Italy
it would be nice to have the possibility to control external DAC (SABRE ? ) volume through i2c port
Michele
Old 2nd October 2013, 08:19 AM   #1476
Nick
Hi Nick,
congratulations for Ver. 1.0.0 and the instruction manual.
If I would have to make the upgrade I would prioritize the items I have marked: 1-3-6 in that order of priority
Old 2nd October 2013, 10:46 AM   #1477
jcga is offline jcga  France
Nick
Hi Nick, nice to see you available again,
here would be my wining combination :
1. : and if possible not only reducing to 8 outputs but if possible from 4 out up to ten
3.
6.
7.
4.
2.
5.
9.
8.
10.
Best
Jean Claude
Old 2nd October 2013, 01:17 PM   #1478
Discussion is open
Best,
Nick
Nick, please add these two items to your list (if it's not limited to 10!)
11. Disable normalization of imported data. (or user selectable)
12. Change remote control volume steps from 3 dB to 1 or 2. (or user selectable)
Priority: 2, 9, 11, 12
Old 2nd October 2013, 01:54 PM   #1479
For me channel pairing would be good, as this would greatly speed up the set-up and tweaking process and imagine (although I have no idea) that it would be easy to tick off the list:
2. Channel pairing/linking - could you have radio buttons or drop downs to set preferred pairing? Or select an initial set-up type for auto linking e.g. 2-way stereo; 2-way stereo, mono sub; 3-way; 3-way plus mono sub; 4-way etc. This could tie in with disabling any unused outputs to save on processing (your point #1). And even better if outputs could then be automatically labelled on the screen too - e.g. Left High, Left Mid, Mono sub etc.... instead out output 1,2,3... Obviously it's important that you know what you're doing when configuring but this would make set up more user friendly. An initial set-up configuration would enable outputs to be configured to optimise balancing of core processing power - i.e. number of outputs could be evenly distributed to optimise processing distribution between cores?
Then:
This would be good too, although not implemented external DACS yet, would have saved me purchasing an external controller.
Old 2nd October 2013, 02:09 PM   #1480
Default NAJDA wishlist
Hi Nick,
I'd go for:
- Channel pairing/linking
- Allow enabling/disabling processing channels in order to save resources
- implementing volume control of external chip for up to 5.1 channels (2CH NAJDA, other external board)
- Allow renaming of sources (LCD)
- while having the driver data imported, to see immediate change in output graph without switching the tabs
- Implement support for expansion board
- extra analog input
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright ©1999-2017 diyAudio
