DSP Xover project (part 2) - Page 131 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th June 2013, 08:09 PM   #1301
chaparK is offline chaparK  Luxembourg
Originally Posted by dahlberg View Post
Thanks, but when using spdif outputs you're a bit limited anyway.
spdif or any other outputs doesn't affect DSP load.
On another matter. In post 1249 you posted a picture of the Wave io
connection. I have connected over the uf-l connectors but I'm getting blinks
from the dsp-overload led. I haven't listened to it yet but I suspect that it will
behave as it did for a few others. Did you try the uf.l connection ? And do you
think that you can find the time to make drawing of the connection. The
picture was a bit unclear.
Connections are detailed in the Startup Guide. The only addition is the power supply to the transmitter part of the WaveIO's IL715. That's just a wire from the 5VD on Expansion Port 1 to the I2S header of the WaveIO (plus the ground return).
Najda DSP
Old 20th June 2013, 08:25 PM   #1302
dahlberg's Avatar
Let's se now, first spdif is for channel one and two. Second spdif is for channel
three and four and so on, rigth ? I can't see any possibility to divide six
channels evenly over these outputs. Am I doing this wrong or...? I will try to
put the midfrequencis on one core since it has most done to it and see what
that gives.
Edit: That worked like a charm :-) 88% on core0 81% on core1.
Basically just moved channel one and two to channel seven and eigth.
Old 20th June 2013, 08:46 PM   #1303
dahlberg's Avatar
This is going great just added a second eq to the subchannels (maybe will
go for a dipolesystem in the future) and that evend it out to 88/86 %
This is at 192khz SR.
Old 20th June 2013, 09:34 PM   #1304
dahlberg's Avatar
Has anyone tried to connect an external dac to expansion port0 ?
Old 20th June 2013, 11:21 PM   #1305
zoula is offline zoula  Canada
Hi ,
I would like to know if it is possible to have 8 I2S output, Is it software limited or hardware limited???
Thank you
Old 21st June 2013, 06:22 PM   #1306
jcga is offline jcga  France
Hi Everyone,
as my current Najda board is currently dismounted, I can't check this right now. could someone confirm the following hardware implementation on the board:
Lower cinch row : Left In/OUT1/OUT3/OUT5/OUT7
upper cinch row : Right In/OUT2/OUT4/OUT6/OUT8
Thanks in advance
Jean Claude
Old 21st June 2013, 07:01 PM   #1307
UrSv is offline UrSv  Sweden
UrSv's Avatar
Not sure why you need the board at all to check this but according to the manual page 14 it is the other way round i.e.:
Upper cinch row : Left In/OUT1/OUT3/OUT5/OUT7
Lower cinch row : Right In/OUT2/OUT4/OUT6/OUT8
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 22nd June 2013, 05:29 AM   #1308
Hi Urban,
Thanks for the answer,
Well I'll have to change my glasses though
Jean Claude
Old 22nd June 2013, 09:38 AM   #1309
Originally Posted by zoula View Post
Hi ,
Thank you
Currently only 6 I2S outs are supported.
It would be possible to increase this number by using some pins of Expansion Port 1. Indeed, the DSP has pin switching capability, i.e. you can reroute pins between I2S ports. I'd need to double check this however.
Najda DSP
Old 22nd June 2013, 10:00 AM   #1310
I've made some progress on my build. I'm still standing by for some pcbs to arrive from China to complete it
Jean Claude
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright 1999-2017 diyAudio
