DSP Xover project (part 2) - Page 111 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th May 2013, 04:37 AM   #1101
Cheap ps option?
1pc DC Switching Power Supply NET 35B 35W 3 O P 5V 3A 12V 1A 12V 0 5A Meanwell | eBay
Old 10th May 2013, 09:20 PM   #1102
chaparK is offline chaparK  Luxembourg
Originally Posted by UrSv View Post
I just checked the board and it is the relay connector that is a little out of Place as it seems the distance is approximately 197.5 mm or thereabouts rather than 201.6 mm.
Nick, any input on the template for the back panel? Is the position correct in Appendix C for the relay connector?
Originally Posted by dahlberg View Post
http://www.dahlbergaudiodesign.se/najda_back.zip
Now it's done. The relay connector is missplaced in the appendix.
It should read 197 instead of 201,6mm. The rest is ok.
Yes, indeed sorry guys, there is a typing error in the appendix. It should read 197.1 instead of 201.6 if you want a 10 mm cut width centered about the connector. The connector itself is 9.2 mm wide.
I'm currently overseas so I can't update the documents on the website. I'll do that in a week. Note that the placement of the cut in the drawing is fine - it's just the reading which is wrong.
Nice job Bengt, and interesting design! So is the board hanging upside down? And the display comes on the top? Looking forward to the finished product
Originally Posted by Flemming J P View Post
I have tried a diyinhk usb interface using a CM6631A and it almost works.
I only get right left channel audio, if I switch to analog input on the nadja everything works fine.
Any clues to what it could be?
Do you mean you have the channels L-R inverted?
Yup, should be fine! And definitely worth a try at this price
Najda DSP
Old 10th May 2013, 09:50 PM   #1103
dahlberg's Avatar
Yepp, it's hanging uppside down. There will be more pictures in due time.
Old 11th May 2013, 11:26 AM   #1104
Crumboo is offline Crumboo  Sweden
Soo...trying to load some coefficients for FIR filtering i Najda Under Control. Tried text files and wav but is getting a "Invalid file" message. What kind of files are expected?
Best regards,
Mattias
Old 11th May 2013, 12:19 PM   #1105
paalj is offline paalj  Norway
Best regards,
Mattias
Hi Mattias,
A text file should do
Have a look at the attached files. This is a minimum phase 2k xo@48kHz.
have fun!
best Paal
Old 11th May 2013, 12:46 PM   #1106
Originally Posted by paalj View Post
Hi Mattias,
have fun!
best Paal
Thanks, your files worked as expected. Can't see what is wrong with my text files then. See the attached file (100 taps):
Old 11th May 2013, 01:18 PM   #1107
There where some spaces in between. Try now
Old 11th May 2013, 02:26 PM   #1108
Thanks again, now it's working! Cool!
Old 11th May 2013, 03:14 PM   #1109
SAC is offline SAC  United Kingdom
Originally Posted by Alterfalter View Post
Hi Nick,
thanks for the fast reply. I ordered the Astec DPT52 (external PSU). I will check all voltages with and without load before I connect to Najda.
Uwe
Any progress on checking the voltage with this? Attractive at that price!
Old 11th May 2013, 03:18 PM   #1110
Hi Nick,
I wonder if there is an issue with the FIR phase display in "Najda under control"?
I am getting some strange displays and can't get it right. See attachment.
best,
Paal
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright 1999-2017 diyAudio
