DSP Xover project (part 2) - Page 109 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th May 2013, 07:30 PM   #1081
chaparK is offline chaparK  Luxembourg
Originally Posted by Shaun View Post
Nick, would it be possible to upload Najda's current configuration to the Najda Under Control software (reverse of how it normally works)? I'm considering a case for recovering the configuration where the setup file has gotten lost or corrupted. This is likely a few years down the line.
Originally Posted by siginitz View Post
Nick, if it is not a problem to implement this feature, I think this could be sometimes very helpful. I am missing this option since I changed from my tweaked DCX2496 to Najda. But this is the only thing I am missing! In my system the Najda board outperforms the DCX by lengths! Very clear, airy, a much bigger stage and dephtness.
OK I put that on the wishlist. I'm not sure whether this is really feasible as this would require to store filtering parameters in the board memory.
The wishlist is growing so at some time we'll need to talk again and define priorities.
Very happy you like Najda's sound Siegfried - especially after having seen a pic of your setup
I got an email from someone suggesting an interesting alternative to LCD displays. I think I'll get one of these to give it a try (along with an OLED) if they're OK to ship it to Europe.
Najda DSP
Old 7th May 2013, 08:23 PM   #1082
JLOP is offline JLOP  France
Indeed as an absolute alternative there would be a nice IOS/Android app ? If feasible, that should go High on the wish list ( guess requires permanent USB / ethernet connexion)
Jean-Louis
Old 8th May 2013, 01:47 AM   #1083
r1968 is offline r1968  United States
Default Noritake VFD
Hi Nick
I bought a 3 unit lot of Noritake VFD from ebay. I will ship out one to you for free. It is an older model though. Let me know if you want one.
For all the work you are doing, it is the least I can do to say thanks
--raj
Old 8th May 2013, 05:06 AM   #1084
Nick, not sure if Its been covered but is there a rotary volume control option?
Old 8th May 2013, 08:43 AM   #1085
dahlberg's Avatar
I needed a back template with center marks so I made a cad drawing (.dxf).
It worked like a charm
http://www.dahlbergaudiodesign.se/najda_back.zip
Old 8th May 2013, 09:09 AM   #1086
UrSv is offline UrSv  Sweden
UrSv's Avatar
Nice. That might come in handy.
Did you adjust the numbers for the USB and relay connector? It seems the numbers are strange (I do apologize if I'm more blind than usual) in the layout document as it seems there is only 0.9 mm between them whereas the template shows more just like the board itself does.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 8th May 2013, 10:34 AM   #1087
dahlberg's Avatar
I measured it with a caliper and the usb + relay took some handywork.
But you are rigth there was a slight fault in the drawing around the usb connector, it's updated now.
Old 8th May 2013, 10:48 AM   #1088
dahlberg's Avatar
Old 8th May 2013, 04:50 PM   #1089
UrSv's Avatar
I just checked the board and it is the relay connector that is a little out of Place as it seems the distance is approximately 197.5 mm or thereabouts rather than 201.6 mm.
UrSv
Old 8th May 2013, 05:09 PM   #1090
dahlberg's Avatar
I will go over the drawing again since there still seems to be some
inconsistencies, and update it when done . Probably tomorrow.
The backplate turned out quite nice anyway. Have made place for
buttons and display as well
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright 1999-2017 diyAudio
