DSP Xover project (part 2)
The cap transfer function depends on impendance - it is text book only to fix impedance /resistor/
S2 isnt fixed impedance so transfer is bumpy.
I bet my wife :) that once you eq response so it overlap in holm you wont heard any difference. When you start think that cap is better do it blind :)
Also i want to encourage everybody to use dsp in combination with passive element. I use DSP just to Attenuate - never to rise level - this way full digital dynamic range is preserved - and IMO - attenuate in digital is always better than plus EQ.
When you attenuate - f.e. low pass - signal with is most affected by DSP and physical DA limitation is in stop band - so potential flaws are many db below pass band. /i know that pass band is also manipulated - but i try to explain it simple/
When u make positive correction - the most attenuated signal is above other signal and potential flaws are more "hear-able"
Simple example HORN CD correction
Cap-resistor parallel together and this serial to driver - make nice HUMP in response tunable with cap and resistor value. Then little MINUS 1-2db correction in DSP = much better than PLUS 10-15 EQ in DSP. Also better S/N
because noise is attenuated by resistor.
Chapark - please if you can make some MATH comment.
ALSO real life DSP example /video for better understanding/
try DARKEN photo /DSP/ - photo is just darker - you dont see DSP artifact because they are hide in shadows.
TRY lighten Photo - you see steps in gradient - increased noise and other flaws - because of processing /steps/ and because you make original signal flaws more visible
Chapark - please comment my knowledge behind DSP math is very limited
That's interesting info - I'll try the reduce never increase and see. Level balance can come in gain / power amp side.
I am trying all sorts and learning = fun. Really need that extra 2 channels for proper 5 way to get to full grips with things;)
Out of parts for a while but it's slowly coming along :)
Are you using tubes as bufferts?
limited
I've just applied this to my 8 channels and after a quick listen / usual test tracks, it works! Great advice.
looks like you'll be correcting for the errors in the output stage too ;) maybe pleasant sounding mate and impressive build with all that copper, duelunds etc, but there will be significant non linearities caused by that output stage that the DSP will be having to/trying to correct for. how much of that tube sound will be left unadulterated? or you will be keepikng it VERY simple with the cxrossover you program?
maybe its pleasing distortion, but its distortion all the same. It seems a strange thing to ask a DSP to do, ie. correct for itself. seriously, kudos on the commitment though. just trying to understand.
looks like you'll be correcting for the errors in the output stage too ;) maybe pleasant sounding mate and impressive build with all that copper, duelunds etc, but there will be significant non linearities caused by that output stage that the DSP will be having to correct for.
Don't you have anything better to do :mad:
look, thats an honest question, did you think that through? see my edit above, i'm really trying to understand. the DSP will be working against the output stage and the output stage will be working against the DSP. how will you know whats caused by what? or you wont be asking the DSP to do much correction? just XO? I expect the tube buffer would sound quite good (not really my taste, but good all the same and a quality example of its type), I expect the DSP sounds quite good. it just seems together they are counterproductive and I wondered what your plan was.
like it or not, the DSP doesnt know what sound comes from where, so unless you are keeping the correction really minimal or non-existent, the DSP will see the error as something to correct for (thats what it is objectively, the DSP doesnt have taste)
you with me? low feedback or simple analogue stages will probably go better with low feedback, or simple digital correction. I figured you had a plan there given the obvious effort and expense.
sorry for the curiosity :rolleyes:
edited arrangement.
Najda and WaveIO
A quick update on the WaveIO/Najda coupling. Sigi had already posted here his findings, but as Lucian (from Luckit, the WaveIO manufacturer) sent a board for testing, I thought that I'd report too.
So I'm happy to say there's no problem whatsoever. The picture below shows my quick and dirty test setup.
There are 4 pairs of signals running between the WaveIO and Najda: Data, Frame Sync and Bit Clock (all with their individual ground return) - and a 4th pair as described below.
The WaveIO is equipped with a bus isolator that must be powered with the external device's supply. That's the 4th pair of wires, in the present case +5VD and DGND pulled from Expansion Port 1 (you could also use +3.3V instead of 5V).
Last thing you can see on the pic is the purple wire loop. That's the connection of IS_EXT1 to DGND (both on Expansion Port 1). This is required to let Najda detecting a I2S input source.
That's great news Nick. will there be any issues supplying 5v from the Najda on board regulator? I believe the WaveIO draws over 400mA
Najda board well received Nick, thank you. Beautiful card, very professionnally packaged.
Great to hear, thanks Jean-Louis!
So this 5V supply I was mentioning is just the isolator chip supply (IL715, see the WaveIO doc for details). The WaveIO board in my setup is powered by the laptop USB port.
If you don't want to power the WaveIO via USB, you should pull a wire from the power supply. +5VD on Najda doesn't go through a regulator, but through a small inductance which is rated for 320 mA. So if you power the WaveIO from Najda's 5VD, you might fry this inductance...
(OT: I'll be away until 17 JUN, might not have internet access until then :spin:)
