DSP Xover project (part 2)
Old 8th December 2012, 11:03 PM   #451
chaparK is offline chaparK  Luxembourg
Yes the routing is totally free.
Your source is a stereo signal with Left and Right components, right?
The DSP generates on top Sum and Diff.
Any of the 4 (Left, Right, Sum, Diff) can be routed freely to any processing channel.
Old 8th December 2012, 11:06 PM   #452
Originally Posted by TNT View Post
The expansion boards - are they just copper or something more?
The projected expansion board would consist in 6 channels of DACs with output filters and digital volume control.
Old 9th December 2012, 07:46 AM   #453
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Cool,
I'll pob get one and then the expansion board, unless it years off and your solution sounds sooooooo good, I simple can't wait
Old 9th December 2012, 08:02 AM   #454
TNT is offline TNT  Sweden
I have to ask... haven't seen a gain structure block schema.. Is this utilized/present and how and where in that case is it executed?
ESS dig vol: http://www.esstech.com/PDF/digital-v...me-control.pdf
Old 9th December 2012, 10:46 AM   #455
Good point - gain structure can be important.
That's one reason why the 2494 DCX's usually sound so dire out of the box - they just don't work in Hifi applications with normal power amps.
That and the crappy output amps at whatever steroided volt output they have...
One other question.
does this one have auto time align - It's feature I love of the Behrigher DCX units. So easy - select it and it makes choo choo square wave noises in each of the drivers in sequence, with the mic in it's all over in seconds and as I measured it aligned my Tapped horns and bass horns perfectly, as well as all the other drivers in a jiffy!
Manual would do of course but takes time honing in 5 ways x 2, using Holmimpluse to measure.
Old 9th December 2012, 03:41 PM   #456
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
If you have your own DAC´s(Run on Spdif)could the digital volumecontrol be used for them?
Regards Åke
Old 10th December 2012, 08:23 AM   #457
alugner is offline alugner  Sweden
One other question.
I think Your question has been up earlier, but regarding level/frequency response. I think the answer was negative. I agree it would be convenient. But the board would need an analog input and a calibrated microphone. (And lots of more programming.) Could You read the delays from the Behringer and enter then manually?
Old 10th December 2012, 09:51 AM   #458
vitalica is offline vitalica  Europe
Hi Nick,
I'm interested in the board with the analogue level control.
Best regards,
Vitali
Old 10th December 2012, 11:00 AM   #459
goosewing is offline goosewing  United Kingdom
Default Yettanother
Also registering interest for one board with analogue volume control.
Rgds,
Rob.
Old 10th December 2012, 04:14 PM   #460
Yes, I understand.
I can use Holimpulse to measure the delays needed and enter them manually of course.
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright ©1999-2017 diyAudio
