DSP Xover project (part 2)
Old 7th November 2012, 01:17 PM   #361
dvisves is offline dvisves  United States
Default testing Class D amplifiers
I have ruined two Class d modules by testing them in the conventional way.I attached the signal generator to the input and loaded the module with a wirewound 50 watt resistance of 8 ohms.I used a compuper based oscilloscope to monitor the out put waveform.As i increased the input signal the heatsink got very very hot and the module stopped working.
I need to explain the reason why i started testing the class d module.There was inconsistency in the advertisements for the amplifier module.The ads said 100watts rms at 4 ohms.Assuming that the the Class D has an efficiency of 85% which is typical,the heatsink would have to dissipate 15watts per channel and total 30 watts for stereo.The heatsink attached to the module was tiny and could not dissipate 30watts by no stretch of imagination.Hence my experiment to determine the true rating of the amplifier.
Can any body point me in the right direction.
deevee
Old 7th November 2012, 01:22 PM   #362
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Originally Posted by chaparK View Post
Na, double precision is my very own prerogative
As the programmer, I'm the one who's deciding when it's required to switch to double precision. So this "switching" happens in the code and is not user selectable.
One less thing you need to worry about
Ok, thanks
Old 7th November 2012, 07:10 PM   #363
chaparK is offline chaparK  Luxembourg
Good news: I managed to convince one of the very best wxWidgets experts to work with me on the control application!
Xavier actually joined the team about a month ago and wrote already many lines of great code. He also set up a SVN server so that we can easily exchange updates and keep track of the changes.
He's now a member of this forum so you might read his posts here some day
Old 9th November 2012, 01:32 PM   #364
dahlberg's Avatar
Good thing that you are getting some help, should take some load of your shoulders
Could you give us an example of when you would activate the "double precision mode" ?
Old 12th November 2012, 05:24 AM   #365
dahlberg's Avatar
Just ordered all external parts, this remote was one of them. Didn't find any other really small one.
I'm hoping to be able to put things together over christmas
Any chance of that happening ?
Old 12th November 2012, 08:52 AM   #366
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I to ordered some parts,but I`m planning to use my Logitech harmony remote.What remote should it be programmed as?
And what pushbuttons to use?
Regards Åke
Old 12th November 2012, 09:54 AM   #367
Filters in the lower frequency range is typically the place where you want to use double precision.
This remote should be fine. I just had a quick look and, well, if you need a really small remote...
More seriously, I like these ones:
- Cute one
- Small key ring
- More keys / more options
- Big mute button
Definitely!
I'm expecting the production sample some time next week. Then the remaining units would follow shortly after.
The board currently supports NEC and JVC protocols. Any layout using one of these protocols is compatible.
After choosing your controller model, the next step is the 'learn' feature of the board that lets you associate a key of you controller with a function.
Supported functions are:
- On/Off
- Mute
- Volume +/-
- Preset +/-
- Preset 1, 2, ..., 9
- Source select
- Balance L/R
- Bass +/-
- Treble +/-
Old 18th November 2012, 07:44 PM   #368
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Well I got me 2 x Behringer ultradrive pros to play with.
Dead easy to set up and it performs quite well.
I was able to try my Lazy ribbon tweeters at a lower freq than before so easily and that gave a good SQ improvement.
So, I am sold on the flexibility and usability of this sort of thing.
I have found ditching the passive gave some nice benefits in bass immediacy. I can run steeper slopes on the Tapped horns and mid bass horns. As my system is time aligned i find L-R 12 slopes on the rest to sound the best at present - more fiddling no doubt to come.
I read up on tests Behringer VS miniDSP, where some preferred the mini and some could not tell the difference...
I think there are definitely ADC / DAC issues with the Behringer, though the ditching of passives has given a win back I think there is more to come from my system if I could get the best of both worlds - Great ADC and great DACs.
How is the project going - I am very keen to try a digit / analogue in and 10 out solution
Old 19th November 2012, 08:01 PM   #369
Ryssen's Avatar
Hows it going with programming?
Could we maybe get a list of what feauters it contains?
Regards Åke
Old 19th November 2012, 09:57 PM   #370
dahlberg's Avatar
I'm actually looking forward to the final presentation, can't be that far away
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright ©1999-2017 diyAudio
