DSP Xover project (part 2)
Old 31st October 2012, 08:11 PM   #321
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
This is getting exciting...
Old 31st October 2012, 08:57 PM   #322
chaparK is offline chaparK  Luxembourg
Originally Posted by chaparK View Post
We already mentioned somewhere in this thread that I could make available volume control of external DACs via SPI or I2S or GPO. That can be of interest for you only if your DACs accept some sort of volume control.
Sorry i meant I2C here above.
Old 31st October 2012, 09:10 PM   #323
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I have the nanoDIGI at the moment and it uses volume on the Spdif I think it´s working fine.
If you don´t have any plans on volume on the Spdif,I could use nanoDIGI only as a volume control before your board.
Are you planning on explaining the feautures of the software?
Regards Åke
Old 1st November 2012, 01:05 AM   #324
Trevor White is offline Trevor White  Australia
Originally Posted by Ryssen View Post
Will there be a PEQ?
Have you any idea ,if used only digital,will it outperform the nanoDIGI
Soundwise?
nanoDIGI 2x8K | miniDSP
that min-dsp board is weird. It has SPDIF outputs but no headers with I2S so you can piggyback it directly on your own DAC board !! Weird or what !!
Old 1st November 2012, 11:05 AM   #325
Ryssen's Avatar
Weird or not,it works with Spdif (and no I2S)wich I knew when I bought it..
Regards Åke
Old 1st November 2012, 02:17 PM   #326
knuisje is offline knuisje  Netherlands
Indeed very weird they don't expose the I2S points on a header.
The nanodigi uses an AK4101a 4-outputs DIT. This ic receives the eight channel I2S signal from the dsp on pins 3-6 and 9-10. You just have to search on the pcb for convenient points to tap these pins.
Old 1st November 2012, 02:22 PM   #327
How about discussing miniDSP products on miniDSP forums?
Old 1st November 2012, 02:23 PM   #328
Ryssen's Avatar
I think the dsp crew knew wich pins it is,it was sommething with the waranty...
Thats weird..
Regards Åke
Old 2nd November 2012, 01:10 AM   #329
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Good idea
How are things coming along ?
Old 2nd November 2012, 11:38 AM   #330
It's all going alright, thanks for asking.
I successfully connected a device on one I2S expansion port.
Just to summarize, this port always works in slave mode - i.e. the device must supply the sync and the bit clock. The board is happy with any sample rate because the data goes through the sample rate converter, spitting out data at the rate selected for the processing (48 kHz, 96 kHz or 192 kHz).
If there's still interest for this, we'll see in a future revision how to organize a master clock fed through that same port. This was requested by a member in this thread, and I had already said that I had made the hardware change to allow this - but we'll need to figure out how to make the software compatible with this option, as that supplied master clock would become the system clock.
I also had the second I2S port working. It's spitting out 6 DSP channels freely routed - i.e. the user selects in the application what DSP channels he wants to collect on the expansion port. This second expansion port always works in master mode: this means that it supplies the sync and the bit clock at the selected DSP rate (again, can be 48 kHz, 96 kHz or 192 kHz).
I'm currently busy with the firmware update procedure which will allow the application to flash the board with a new firmware - for both the DSP and the MCU.
Regarding hardware, it's all fine although a bit slow, sorry again for this. The PCBs have been manufactured and the stencil for assembly is ready too. We're currently waiting delivery of the last components in order to start assembly. This is unfortunately out of my control because some parts have an um-compressible lead-time.
Cheers
Nick
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright ©1999-2017 diyAudio
