DSP Xover project (part 2)
Old 8th July 2012, 02:23 PM   #21
mvaldes is offline mvaldes  Italy
Originally Posted by hochopeper View Post
Well consider me thoroughly interested!
one more here
Old 8th July 2012, 02:31 PM   #22
ds23man is offline ds23man  Netherlands
ds23man's Avatar
This is getting very interesting. What kind of Dac's?
I am fed up with waiting for the Hypex DLCP.......
Old 8th July 2012, 02:34 PM   #23
ds23man's Avatar
Can you post some pictures with more resolution?
Old 8th July 2012, 02:34 PM   #24
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by chaparK View Post
Sounds good!
indeed it does! and local too!
might I suggest/ask/plead that you have optional u.fl pads for the i2s and MCK in and out? they take up almost no space and are totally SMD, so only need a pad and a via. makes for compact, neat and very effective impedance controlled connections and is starting to become a bit of a standard with any luck. 2 x USB->i2s boards, 1-2 dacs and the i2s fifo so far and its picking up steam.
Old 8th July 2012, 02:53 PM   #25
chaparK is offline chaparK  Luxembourg
Originally Posted by mvaldes View Post
one more here
Thanks, I'm very happy you like the project!
The boards you see on the pics I've posted so far are just prototypes.
Batch production hasn't started yet and these boards will be likely to look (slightly) different.
Old 8th July 2012, 03:00 PM   #26
ds23man's Avatar
Maybe the final batch will be different, higher res pictures are still welcome to satisfy my hunger!
Old 8th July 2012, 03:04 PM   #27
ds23man's Avatar
Dac's???????
Old 8th July 2012, 03:19 PM   #28
qusp's Avatar
see my edit for request, i'm suggesting you add these like on ians i2s fifo board. this is a close up if an adapter he made but shows well, I have w.fl its smaller brother on my ackodac for the native connections and its on a few more recent boards released here for clock and i2s interconnections. not exclusively, just as an option as they take up so little space and should not interfere with layout when placed in parallel to a pinheader or whatever.
Click the image to open in full size.Click the image to open in full size.
Old 8th July 2012, 05:11 PM   #29
Hi DS23man, more pics will follow shortly when I receive the first batch. I'm not eager to post detailed pics of a changing layout as this will cause confusion, hope you understand.
Thanks for the suggestion. So my understanding is that you'd like to see pads for mini coaxial sockets, is that correct?
Old 8th July 2012, 05:56 PM   #30
qusp's Avatar
yep, for i2s and clock. they are sold under a few different names, but the one that will always get hits at digikey or mouser is u.fl. They are 50ohms and good for up to 6GHz; most often used for connecting wifi antenna in mobiles or lappies, but they are perfect here for i2s and clock I/O.
they are called U.FL, UMC, or AMC depending on brand, but I use the Hirose U.FL the TE connectivity branded is fine too and about half the price. also for clock adapters instead of or as well as a dip type adapter the SMD female (only hirose make this one) would be perfect
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
