DSP Xover project (part 2)
Old 20th September 2012, 07:19 AM   #251
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
And the programming is almost done ?
Old 20th September 2012, 08:06 AM   #252
chaparK is offline chaparK  Luxembourg
Actually yes we can say so.
Micro-controller code is completed. That includes all SPI peripherals management, LCD, IR sensor, USB communication etc.
DSP code is nearly done.
Most of the remaining work is on the control application. It's of course already communicating with the board and I have big chunks in place under Windows and Linux.
Old 20th September 2012, 08:25 AM   #253
alugner is offline alugner  Sweden
I must say. Isn't this a vast programming task? A couple of platforms and a gui as I understand. Are You doing all by Yourself? (I'm in the programming business myself, database oriented applications.) I'm impressed even if You wouldn't succeed.
Best wishes.
Old 20th September 2012, 08:35 AM   #254
dahlberg's Avatar
Looking forward the presentation
Old 20th September 2012, 12:27 PM   #255
ds23man is offline ds23man  Netherlands
ds23man's Avatar
maybe a sneak preview of the board design
Old 20th September 2012, 01:24 PM   #256
Samyk is offline Samyk  Germany
would it possible to order a board without the rca connectors? i don't need them and desoldering is alway a risk to damage the board. i only need the digital inputs and the usb connector.
Old 20th September 2012, 11:43 PM   #257
YouAgain is offline YouAgain  United States
Do the digital inputs and outputs have transformer isolation?
Old 21st September 2012, 04:03 AM   #258
Best wishes.
Yes that's a lot of work. There are other things coming on top such as schematics, PCB design and filters design. It's going to be fine
So I'm right now looking at quotes from the PCBA manufacturer. Lead time is 40 days and I'm requesting first 1 board to make sure there's no issue with assembly (there's over 400 components on each board). I'll post pictures of the first board.
That should be doable, to be confirmed.
All outputs are isolated (5 transformers). Input is not isolated - I made here the assumption that the line is isolated on the source side, which is usually the case in my experience.
Old 21st September 2012, 09:06 AM   #259
ds23man's Avatar
So you will have the first board in the end of october, do some checking and the first batch will finished in december????????
Old 21st September 2012, 09:37 AM   #260
I'm doing as fast as I can. If there's no problem with component sourcing then the batch will follow shortly after the first unit has been received.
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
Copyright ©1999-2017 diyAudio
