DSP Xover project (part 2)
Old 30th August 2012, 11:28 AM   #211
jtwrace is offline jtwrace  United States
jtwrace's Avatar
Originally Posted by chaparK View Post
Thanks all for your feedback!
I read again your post and I saw the light this time
Now that I understood your question, yes I can confirm you're right: the board will perform nicely without the volume chip. The fact you're managing the signals to your loudspeakers elsewhere means that you have another way to control the master volume - so indeed you wouldn't need the expensive CS3318. Again, if you feel later the need of that chip because you've changed your system for example, you can just solder it on the board and it's automatically taken care of.
OK. Sorry for the confusion.
Thanks for clarification.
"Science is not a democracy"- Earl Geddes, Ph.D.
Old 30th August 2012, 01:10 PM   #212
chaparK is offline chaparK  Luxembourg
Originally Posted by ChrisPa View Post
Just to confirm,
even if the analogue gain chips are fitted the board can still be used as digital only?
ie.
digital inputs -> dsp -> digital gain -> digital out
Wow I didn't understand that one neither yesterday
Yes sure, even with the analogue chip fitted you can use the board digital only. The analogue volume chip doesn't affect anything happening on the digital signal path. Sorry about the confusion.
Old 30th August 2012, 02:35 PM   #213
mvaldes is offline mvaldes  Italy
Chapark, since the CS3318 will be controlled through the I2C bus, could be possible to control the volume of some external DAC like BuffaloII/III?
Old 30th August 2012, 02:43 PM   #214
CS3318 is actually controlled through SPI.
Both SPI and I2C are however available on the expansion ports.
At this stage there's no volume control for an external device, the main reason being that there's no standard for this: each chip has different addresses for the registers that hold the volume values, and these values are interpreted differently.
In a later release however if there's such a request, we can look at it and see how we can make it possible for a specific chip. Stay tuned
Old 30th August 2012, 02:55 PM   #215
when you say a later release you are talking about HW or SW?
Old 30th August 2012, 02:58 PM   #216
Software/Firmware release
Old 30th August 2012, 03:23 PM   #217
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
I'm considering to go the same way as "qusp" with the "Ackodac's" but
maybe not for all channels so this is getting better and better (if it will work)
Will it be possible to adress 4 output-channels to I2S and the remaining 4
to the analog output section. Or is there signal sent both ways for all channels
at all times?
Old 30th August 2012, 03:24 PM   #218
ok, very good. thank you
Old 30th August 2012, 03:34 PM   #219
at all times?
Here's a summary of what's available in terms of outputs.
Inside the DSP, there are 10 output channels internally.
- All channels 1 to 10 are on SPDIF outputs.
- Channels 1 to 8 are available also on analogue outs.
- There are 2 expansion ports with I2S. They are different but for now it's enough to know that one port can carry up to 6 channels, and the second port can carry up to 12 channels. You can assign to the I2S lines any channel 1 -> 10.
Old 31st August 2012, 05:44 AM   #220
dahlberg's Avatar
Great Are the 9th and 10th channels supposed to be for unprocessed output ? Maybe for a headphone amp
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
