DSP Xover project (part 2)
Old 13th November 2013, 11:14 PM   #1631
chaparK is offline chaparK  Luxembourg
Originally Posted by dahlberg View Post
The button is ok
Maybe I have missid it but, is there a list of what features you where
planning to add for the next SW release ?
What is missing for the next official release is the FIR/IIR mix. I'm also looking at some more enhancements of the GUI.
Originally Posted by Ryssen View Post
Here`s another request:Is it possible to have separate input gain for coaxial - optical - Analog?
I connected a tuner to the analog and I have to lower the gain to -7,5db to avoid dist,
the satteleite on the optical is ok with 0db and at the coaxial I have to lower to 60% at the laptop so they are quite uneven.
There is probably something wrong about your approach to input gain. Normally, you should set the output level of your digital sources to 0 dB. This way you ensure that full resolution audio is feeding the DSP. Then you should set the analogue gain on your source such a way that the signal is near to full scale in the ADC. The clipping led will help you to set the appropriate gain.
If you proceed like this, then all you signals take profit of the full dynamic range and you don't need to set different gains on the DSP.
Najda DSP
Old 14th November 2013, 02:21 PM   #1632
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
The 0db I am aware of,but the optical and the analog source dont have variable level only the laptop.
Regards Åke
Old 14th November 2013, 03:27 PM   #1633
Ryssen's Avatar
Ok I got a god compromise now the inputgain is lowered to -6db so that no one of the sourced clipps.The analog is a little louder then the others.Maybe I´ll do a box with a pot
on the cable to the tuner later..
Regards Åke
Old 14th November 2013, 09:17 PM   #1634
Ryssen's Avatar
Uhmmpf...What does it mean when the LED for the output processing clip lights up sommetimes,It does so even if I turn the inputgain down to -24db.
Regards Åke
Old 14th November 2013, 10:54 PM   #1635
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Hej Åke.
Have you tried turning of the "bass/treble" option ? Under settings.
Best regards. Bengt
Old 15th November 2013, 10:28 AM   #1636
Ryssen's Avatar
Yes, the bass/treble is off.Wondering if it has sommething to do with the post gain (and pre gain)?How they are in relation to each other.
Regards Åke
Old 15th November 2013, 08:05 PM   #1637
tommygun is offline tommygun  Latvia
chaparK, i've sent you an order for Najda DSP (through your site), did you received it?
Because no reply.
thanks
Old 16th November 2013, 02:45 AM   #1638
smf is offline smf  United Kingdom
Here's a photo of my Najda. I've now got the hard work of sorting out the filters, but I'm really pleased so far. Thank you so much! (NB: I used the Meanwell 35B power supply - it seems to work well. The 'buttons' are all spring return switches - the up/down and left/right being two way. I've yet to do the IR. The LED is from eb@y - despite the fact that I live in HK, sourcing that was painful!)
Old 16th November 2013, 09:41 AM   #1639
UrSv is offline UrSv  Sweden
UrSv's Avatar
The Najda is now playing music through my "big" DIY speakers (Seas T25CF002, prop 6.5" mids and prop 12" woofers) with my three channel LM4780 amps. If it works out I'll build another amp that will be 6 channels in one.
For some reason the IR receiver is not working but I'm sure that's my fault so I'll fixa that later. First I want to adjust the Najda for a rough initial setup. So far I'm just testing with woofers crossed at LR24-80Hz, mids at LR24-80Hz/2500 Hz and highs at LR24-2500 Hz. Sounds pretty good so far.
Excellent stuff Nick!
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 16th November 2013, 01:04 PM   #1640
Ryssen's Avatar
Nice to hear that your getting the builds to work.
But one problem here is that the clip warnings don`t turn on instead I get a cracking sound if the digital level seems to high,don`t how yours Nadja does?
Regards Åke
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
