DSP Xover project (part 2)
Old 8th August 2013, 09:56 AM   #1441
JLOP is offline JLOP  France
Yes, recommended by Lorien, I think better immunity to noise but do not know by what extent. Keep us posted (;-), will try myself when back home from vacations.
Old 8th August 2013, 11:08 AM   #1442
UrSv is offline UrSv  Sweden
UrSv's Avatar
Originally Posted by dahlberg View Post
It's this one but they seem to be sold out
Now on:
Heavy Duty Dual Linear Technology LT1083 LT1083CP Adjustable DC Regulator | eBay
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 10th August 2013, 06:59 PM   #1443
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Will there in the near future be an option that links 2 channels,so that when you change one channel the otherone changes to?(stereo)
Regards Åke
Old 13th August 2013, 07:22 PM   #1444
zoula is offline zoula  Canada
I've been searching the web for a dual voltage power supply for the Najda. Did someone have a few links, Preferably for North American supplier
Thank you
Old 14th August 2013, 08:11 AM   #1445
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Hi.
Would it be possible to make a function for a combined L/R input gain that is
also available from the pushbuttons ?
Old 15th August 2013, 06:34 AM   #1446
chaparK is offline chaparK  Luxembourg
I'm just back from my holiday, sorry for the late reply.
A friend of mine wanted a "Najda" as well so I'm helping out
Great build again indeed Bengt! No LCD/keypad/IR sensor?
Yes.
Thank you
This model has been tested by several users and is available at Mouser in the US:
MTW30-51212 TDK-Lambda | Mouser
Hi.
Are you thinking of a digital gain?
Najda DSP
Old 15th August 2013, 08:16 AM   #1447
dahlberg's Avatar
The function already exists in the "input processing menu" but as separate left and rigth input gain, and yes it's digital.
Is it it possible to create a combined function that is also available from the pushbuttons ?
"Samuel" wants to try it without pushbuttons and display, just a remote for volume.
There will be 100% use on the exp1 input and all other settings will be available from
software so..... Maybe he will change his mind but we will try it like this at first.
Old 16th August 2013, 07:55 AM   #1448
I don't really understand why you would do this. If your input level is too low, you should boost it prior to getting into Najda. Indeed, an input digital gain will raise the noise floor.
Or am I missing something?
Alright. In any case, it looks good!
Najda DSP
Old 17th August 2013, 07:15 PM   #1449
dahlberg's Avatar
I had some problems with digital clipping on a few records and I went at it the wrong way. Problem solved by doing it the right way instead
There is a dipole compensation that was something like +12 db and an adjustment in level for -12db. If I adjusted for level in "post gain" there was digital clipping no matter how much I lowered it. If I instead lowered it at "pre gain" the problem was solved.
I have to lower the input gain (input menu) a little bit (-3db) now as well to avoid digital clipping.
Not a problem since I now can play more then loud enough.
Edit: So from my point of view, you can drop this question.
Old 28th August 2013, 10:34 AM   #1450
dahlberg's Avatar
Hello again.
Time compensation is done in samples and is also displayed as such, togeher with ms.
I think that the number of samples is quite uninteresting but I would like to
have an indication of distance. Would this be possible ?
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
