DSP Xover project (part 2)
Old 11th July 2013, 09:52 AM   #1391
SAC is offline SAC  United Kingdom
Copper and wood must give great damping characteristics. I like the socket panels recessed in the wood. Form and function beautifully done!
Old 11th July 2013, 10:11 PM   #1392
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Great handles as well
Old 12th July 2013, 05:44 PM   #1393
Bud Barnez is offline Bud Barnez  United Kingdom
Originally Posted by dahlberg View Post
There is some missing cables and some minor things left soo......
Lovely build.
Can't see any power supply in there. Presumably you will have a separate chassis for the monstrous power supply required to feed this beast.
Old 12th July 2013, 10:33 PM   #1394
dahlberg's Avatar
Originally Posted by Bud Barnez View Post
Lovely build.
Yepp
Old 14th July 2013, 05:02 PM   #1395
MBA is offline MBA  Czech Republic
Default Astec DPT52 (external PSU)
Originally Posted by Alterfalter View Post
Hi Nick,
thanks for the fast reply. I ordered the Astec DPT52 (external PSU). I will check all voltages with and without load before I connect to Najda...Uwe
Hi Uwe,
any experience already with the Astec DPT52 external PSU? The product sheet states high minimum current for 5V as well - is there no problem in your build? Thnks, Mike
Old 15th July 2013, 09:51 PM   #1396
Alterfalter is offline Alterfalter
Hi MBA,
my project is delayed. Too many things, too little time.
However, I tested the DPT52.
Without load the output voltage is not stable, the 5V output oscillates between 4.7V and 5V, the +12V between 10V and 12V, the -12V between -10V and -12V.
With recommended load the output voltages are stable.
With too much load the voltage oscillates between 0 and specified voltage. I guess the short circuit protection kicks in.
I did not measure overvoltage in any case. So the PSU should be safe for the board. However, I strongly recommend to use the right range of load (by adding a shunt resistor).
Uwe
Old 16th July 2013, 11:24 PM   #1397
I did not measure overvoltage in any case. So the PSU should be safe for the board. However, I strongly recommend to use the right range of load (by adding a shunt resistor). Uwe
Good news - thanks! Looks like reasonable compromise between loading shunt, Najda function and power efficiency can be checked without undesirable blue smoke...;-)
Old 22nd July 2013, 05:08 PM   #1398
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Default Expansion board
Nick, how's it going with the expansion board progress?
I am very happy with the 8 channels I have but would love to get the tweeters under Najda control.
Old 22nd July 2013, 08:56 PM   #1399
chaparK is offline chaparK  Luxembourg
Hi Steve,
Sorry that it's taking so long - I'm currently contracting for other people (programming more audio stuff on a Sharc ).
It's actually a coincidence that you're asking now because I've sent yesterday the files to the PCB plant in order to get a quote and a leadtime.
If more Najda users are interested in the expansion board, please let me know here on the forum or drop me an email. This is not a CG, it's just a way for me to estimate the number of units that I should order. It's too early to give you a price, but it's going to be for sure much cheaper than Najda as you would expect.
The expansion board will connect to Expansion Port 0 and will provide 2 more analogue outs with analogue volume and full firmware support - without any DSP load penalty as these 2 channels are already exist in the system (they are chans 9 and 10 in the GUI, available as SPDIF only for now).
Best,
Nick
Najda DSP
Old 23rd July 2013, 12:16 AM   #1400
Beau is offline Beau
Im in, any idea on the size of the PCB?
DSP Xover project (part 2)Hide this!Advertise here!
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 11:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 06:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 07:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 08:39 PM
