Help needed building a DAC
Old 28th June 2012, 07:01 PM   #1
atupi is offline atupi  Romania
Default Help needed building a DAC
i have started building this project and i was planning using PCM1794 instead of 1796 but i have discovered that this DAC's are not pin to pin compatible.
I'm not very used with digital circuits but after some reading i have discovered that 1796 needs some uC to be controlled and 1794 does not.
Knowing that 1794 can be hardware controlled is there any problem if i decide to install a PCM1794 and make de pcb adjustemts and leave the pins from Atmega16 not connected to the PCM like they where designated to be connected to 1796 ?
I suppose (hope) to remain active the source selection implemented in the Atmega16.
Are my ideas viable or i need to make some software adjustments in Atmega ?
Many thanks!
Adrian
Help needed building a DACHide this!Advertise here!
Help needed to start F3 building laama86 Pass Labs 2 26th November 2010 01:15 PM
help needed in building 2-way speaker crossover davidgale Multi-Way 1 25th September 2009 01:37 PM
Help needed building loudspeakers sogens Multi-Way 6 5th October 2007 08:11 AM
Building Fostex 126E Help needed ddmddm Full Range 1 16th December 2005 06:44 AM
Help needed building a sub... gerbruggeman Subwoofers 10 3rd October 2003 02:43 PM
Copyright ©1999-2017 diyAudio
