Anyone "regenerated" USB power line ?
Old 14th June 2012, 10:16 PM   #1
nowhere is offline nowhere  Israel
Default Anyone "regenerated" USB power line ?
There is a whole bunch of DACs nowadays requiring single +5V power supply. And the DACs are often intended for USB, so the +5V comes from USB.
USB host controller in its turn gets its power from the computer PSU, and typically the PSU is "dirty", so the USB +5V is most likely dirty too.
So, practical questions.
Has anyone "played" with assessing USB powered DAC sound quality as a function of USB +5V noise + ripple ?
Has anyone tried to improve the situation ? If yes, what was the approach ?
For example, it is possible to double the +5V into +10V, and then to use a linear low noise regulator to get back the needed +5V, but the voltage doubler should not be "evil" introducing more noise with which the linear low noise regulator won't be able to cope.
Old 17th June 2012, 05:46 AM   #2
barrows is offline barrows
Default Simplest...
solution if one is using a DAC or USB-SPDIF converter which uses the 5VDC power from USB, is to build a breakout adapter which brings out the 5VDC connection point (and breaks this connection to the computer) and the ground connection (but this must stay connected to the computer) and then apply a low noise regulated supply externally.
Back when I used a Wavelink Async USB interface I made this mod and it made a nice improvement to sonic performance.
Old 17th June 2012, 07:02 AM   #3
sandyK is offline sandyK  Australia
Default USB Regeneration.
Nowhere
There are some ideas at the attached link. Despite the protestations from an R.G. member who is an EE,(with views similar to your own posted views in DIYAudio), that it can't possibly make any difference, quite a few were constructed by other R.G. members with very positive results.
It should be just as effective on USB powered DACs as it is with external HDDs, Optical devices and USB memory.
As the highly experienced "Barrows" has already said, the noisy +5V from the PC should be isolated.
There is a simplified version on p.4 of the thread.
Alex
Rock Grotto Audio Forum - For Headphones - Headphone Amps - Amplifiers - X-Can V2 - Musical Fidelity - headphone Discussion - Amplifier Discussion - DIY - Amplifier Kits - Projects - SCHA - Sennheiser - Beyer - Grado - Audio Technica - Headphone amp
Full info on the JLH PSU Add-on is at Greg Erskine's homepage. Click on Power Supplies. Other Super Regulators could also be used instead of the JLH.
Greg's Web Site
Old 17th June 2012, 03:10 PM   #4
I am not sure I understand what you mean.
In this thread I am not interested in some kind of clean external power supply. I am specifically interested in using USB +5V as primary source and cleaning it. I.e. let's assume I have a design requirement not to bring into the pictures external power supplies, I am only allowed to use USB +5V.
Old 17th June 2012, 04:24 PM   #5
Originally Posted by sandyK View Post
Nowhere
Alex
Greg's Web Site
I followed the links. The forum one requires forum membership in order to see full sized schematics, and I am not a member of that forum.
Anyway, I think it's not what I need. If I understand correctly, the folks entertain the idea of an "electronic capacitor". I.e. active circuitry which monitors ripple and tries "to do the opposite".
Alas, this doesn't quite work. Because no amplifier has infinite bandwidth and ripple nowadays is quite wide band, especially from computer PSUs.
I want something else:
1) to increase the voltage using some kind of switching power supply;
2) to filter the output combining capacitors and transistor filter. The latter is the simplest one like at the top of kpdf http://brettcave.net/howto/circuits/...BJT-Simple.pdf .
HF ripple rejection is determined in the worst case by the transistor collector-emitter capacitance and output capacitor - they form C-C AC voltage divider.
From AC point of view base voltage is constant, and since the transistor is used as emitter follower, emitter voltage is constant. I.e. ideally as long as the transistor is not in saturation, ripple is "passively" rejected (and that's the key). By "passively" I mean that dynamic impedance between collector and emitter is high and output impedance, since it is voltage follower, is low.
I have actually implemented such a circuit and it works. The devil, as always, is in the details. E.g. what to use as the second switching power supply increasing USB voltage.
At the moment I have BJT based voltage doubler. At least, it is better than NE5556 based one I had earlier - less visible wideband spikes.
I can buy a LM2577 based step up converter on eBay. Until I buy it I can't know how the spikes look.
Or I can start looking for stuff like this: http://cds.linear.com/docs/Application%20Note/an70.pdf (LT1533) - the article is quite interesting, by the way.
But whenever it comes to switching regulator, physical implementation of the board, parasitic inductance and capacitance, etc, becomes crucial.
Old 17th June 2012, 04:41 PM   #6
Default OK...
It seems like it would be easier to just implement an external low noise supply, but clearly you have other needs.
It also appears like you are ready to try this approach, please let us know how it goes. My own feeling is, that the regenerative approach may cause some problems of its own (noise) and you will have to be careful to keep the losses to a minimum: computers supply at most 500 mA via USB, and some do not meet that spec at all. Some USB audio interfaces require almost the full 500 mA, so you are going to have to keep the losses low.
Good luck!
Old 17th June 2012, 04:46 PM   #7
http://datasheets.maxim-ic.com/en/ds/MAX743.pdf - nice recommendations on checking whether noise is real or not - pp. 9-10.
Honestly, I have a bad oscilloscope probe - not according to the recommendations.
OTOH, lowering slew rate of the switch is a good way to decrease the wide band spikes (and efficiency ).
I'm wondering if a capacitor tied to switching transistor collector in LM2577 can reduce slew rate and decrease spikes.
Old 18th June 2012, 12:48 AM   #8
Part of the problem is the coupling of the SMPS noise from the +5V Vbus into the adjacent D- and D+ twisted pair. Many people report improvements when using expensive USB cables with improved separation between the power and data leads. Some USB cables have these leads in separate cables, only coming together at the plugs. Look at the +5V Vbus lead at the device end with a CRO, and you will even see low level packets of data in the noise when the device is operational.
BTW, the JLH PSU add-on has been demonstrated by a Sydney member to remove a 1V p/p 100kHz triangular wave on top of the DC from a specialised PSU, into the residual noise level .It has been verified by many people to also work well with +12V and +5V SMPS plugpacks used with external devices.
Improvements such as quietening external Optical readers both from external vibration, and greatly reduced ripping errors when using dBpoweramp have also been reported.
Old 18th June 2012, 01:02 AM   #9
I don't doubt people tested the circuit and saw improvements. But, as I said, "strategically" the approach of chasing HF ripple and trying to compensate for it dynamically doesn't look good to me.
I prefer to deal with HF ripple using passive means. And the transistor filter I described is still passive because it uses huge collector-emitter dynamic (dU/dI) impedance and load impedance as voltage divider. Since load impedance is much lower than collector-emitter dynamic impedance, the voltage divider attenuates ripple significantly. But it is still passive approach.
To put it metaphorically, in this case I prefer wide band passive brute force to electronic band limited smartness .
Old 22nd July 2012, 07:58 PM   #10
pj smith is offline pj smith  United States
Default breakout adaptor
I've made several attempts to input clean battery and or linear psu to my Stello U-3 by interrupting the the USB power from my 2010 mac-mini and inserting the 5v external supply. The Stello's red LED indicates power on but fails to turn green when the music streams. The D+ and D- lines must work by triggering something that the mac-mini's 5v output recognize's. Sure puzzles a body...help anyone?
Anyone "regenerated" USB power line ?Hide this!Advertise here!
Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? edbk PC Based 0 1st May 2012 03:40 PM
"Ideal" power line from Service Panel Jim Leach Construction Tips 89 30th April 2010 03:36 AM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 08:47 AM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 05:33 PM
"log line" and "pressure chamber" skrivis Multi-Way 0 21st April 2005 04:55 PM
Copyright ©1999-2017 diyAudio
