Here is some more info.. This audio source is a headunit that connects to an amp.. Im trying to upgrade amps.. I want to convert the SP DIF to RCA. volume up and down left right etc is controled by can bus, but im just going to add a manual volume control..
Pin 5, 6, 15 are the outputs
Pin No.Connector ADescriptionRemarks1 --2 --3 --4 --5SP DIF groundTo EXT AMP6SP DIF (+)To EXT AMP7ALTALT L8Illumination (+)Rheostat from vehicle (+)9R PositionR Signal10 --11 --12NAVI AMP (-)Used for voice recognition13NAVI AMP (+)Used for voice recognition14 -15SP DIF (-)To EXT AMP16DOORDoor unlock signal17Illumination (-)Rheostat from vehicle (-)18Remote antennaRemote supply for motorised antenna
