diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Line Level (http://www.diyaudio.com/forums/digital-line-level/)
-   -   PCM2707 Line-Out schematic (http://www.diyaudio.com/forums/digital-line-level/212977-pcm2707-line-out-schematic.html)
artur36 20th May 2012 10:21 AM
Hi
I plan to make a pcm2707 based soundcard board to output sound to a amplifier I search for that in google but I only find schematics for I2S output or with the pcm2906 chip can anybody helpme getting the schematic or should I go to the pcm2906 aproach
G Netix 20th May 2012 10:56 AM
Hi! I'm new here but I plane to make an USB DAC too but for monitoring. In my mind the best way is to use PCM2707 outputing I²S and a DAC as PCM179x on the same board, because PCM179x are 24 bit whereas PCM2707 is only 16 bits. Another point you may take care is if you use PCM179x, you may use a current/voltage converter. It's not complex, but it takes more place on a pcb. So in my mind each case is good, so you just have to chose the one corresponding to your need. for the schematics, you should use the ones of the datasheet of each device ;)
artur36 20th May 2012 06:13 PM
For me 16 bits is enough because is my first audio project and the pcm2707 is wath i have in hands i have looked at the datasheet first but the schematics provided is a generic one without the values of capacitors and without the pcb design and i don't have experience in pcb design, wath i search is a eagle file or other similar that i can leave in a company to produce the pcb for me
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
