Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st August 2012, 10:57 PM   #81
Originally Posted by iancanada View Post
I'm sure you'll become an expert after you fix your BIII .
Ian
I learnt a lot from experts here (of course including you, Ian) but also paid a lot
This is my first time handling SMT devices. Remove the chip is easy but putting the new chip onto the board should be a lot difficult
Old 22nd August 2012, 02:45 AM   #82
Practice make perfect. I like to use a lot of flux when doing SMD, especially 'spider' IC, a magnifier and small flat tips soldering iron help a lot. Search for the technique in YouTube. It is fun.
Old 22nd August 2012, 03:07 AM   #83
iancanada's Avatar
Yes, finding some video from youtube would be help.
Keep the old solder paste on pads, try this one: SMD29130CC Chip Quik Inc | SMD29130CC-ND | DigiKey
place your new chip exactly on position, with a little metal piece pressed on top, then your SMT station. I'm sure it will be perfect job.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 22nd August 2012, 07:43 AM   #84
Coolhead
Thanks very much for your advice.
Ian
I've bought the Chip Quik as per your suggestion. The chip will be delivered tomorrow and hope I have good news to tell.
Old 22nd August 2012, 05:03 PM   #85
Originally Posted by bigpandahk View Post
Coolhead
Ian
After you put in the new chip, make sure you check the pins if the short is still there before power on.
Old 22nd August 2012, 11:19 PM   #86
Yes Sir
Old 23rd August 2012, 03:18 PM   #87
Received the chip today and put it onto the PCB. To align all the pins is not a easy task. A little press will move it away. I finally use the soldiering iron to fix two pins then use the SMT station. The hot air blowed away one of the capacitor on the PCB and I can't find it.
Measure the resistance between DVCC and GND, > 1.2Kohm. everything seems fine.
Put back all the tridents, connect it to the bench PSU. Power up, all LEDs on including the "Mute". Current is around 650mA.
But after a few seconds, the "Mute" LED off and occasionally flash. I measure the output voltages of the tridents, both DVCC and VDD output are below 0.4V.
Seems something still short.
Old 23rd August 2012, 04:49 PM   #88
You should pull out tridents and separate test it out with separate 5v power supply. You should test out other modules also, it could be more problem. You could be un-doing all the hardworking without testing out every module, 1 faulty module could create the same chain reaction.
Old 24th August 2012, 06:06 AM   #89
I've tested all the tridents before put it back to the BIII. I don't know the way forward, whether buy a new BIII or spend more time and money to trouble shoot the BIII
Old 24th August 2012, 09:02 AM   #90
I have no idea how Ian's adapter is designed and if it automatically disables the onboard power for the clock, One of the Tridents feeds the onboard clock crystal. If you are feeding an external masterclock signal I would expect that the Trident and supply to the onboard crystal needs to be disconnected. Hope this helps.
David
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 1258 Today 04:56 PM
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 2786 16th May 2013 10:22 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright ©1999-2013 diyAudio
