Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV - Page 57 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th February 2014, 03:43 PM   #561
mcluxun is offline mcluxun  United States
Originally Posted by bigpandahk View Post
mcluxun
The heatsink for the two SSLV seems too small, you better test them with a dummy load see if the heatsink is large enough. Facing the heatsink of NTD1 upside down is not good (same as mine), but at least you have to put it outside your casing. It generates lot of heat and must not be trapped inside the case.
I am using a case for power amplifier with two large heatsinks at both sides in addition to the big heatsink for NTD1 and the unit is still getting very hot.
Thanks for the advise.
You are right all of them get pretty hot after 30mins or so.
So I ultimately decided to go with a fan and trying to pwm control it with arduino according to the temp on the heatsink.
So facing the heatsink upside down actually creates a tunnel for the wind.
I have tested my ideas out yet we will see how that goes when everything is in place.
Old 13th February 2014, 08:36 PM   #562
@bigpandahk
Hey did you happened to have the document for the lcd display you use?
The one I found was quite blur about the size of the panel and mounting holes, which made ordering a front panel quite risky for me.
Old 14th February 2014, 11:39 AM   #563
Originally Posted by mcluxun View Post
@bigpandahk
I don't have the document, I have to measure all the details and is in the process to prepare the drawing for front panel!! It took me several weeks already
Old 14th February 2014, 05:40 PM   #564
Only one I found on the sainsmart 3.2. Didn't even specify the screen size.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4449 Yesterday 07:18 AM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2438 24th June 2017 11:28 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright 1999-2017 diyAudio
