Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 17th November 2013, 08:37 PM   #541
mcluxun is offline mcluxun  United States
Originally Posted by Crom View Post
Thank you for a very interesting and informative thread. I am part way through reading it as I am about to change my buffalo IV stage and add Ian's FIFO stage to it.
I've come across mention of the NTD1 but having searched there seem to be a few threads dedicated to this and I can't work out which is the definitive read. Can anyone send me some links to the most up to date info and the GB?
Thank you,
Crom
please note that the 400ohm 15w resister in the bom TN15P400RFE Ohmite | Mouser
Dont have a mounting hole, which becomes a PITA to get a good contact with the heatsink.
Dont fail into the same pit fall I got into.
Old 27th November 2013, 07:59 AM   #542
Crom is offline Crom  United Kingdom
Hmmm, thanks for the help McLuxun. Do you have a suggestion about how to approach this? I love the copper by the way - it looks like a good idea as long as it'll take the heat!!
Old 27th November 2013, 10:16 AM   #543
Having done a lot of reading and spent a bit of time untangling the various threads I've put together a list of useful links. I think I’ve got this right but please let me know if different!
Hopefully these links will be useful to people just arriving at this great looking project.
Development Thread: http://www.diyaudio.com/forums/digit...1-ess-dac.html
Build thread: http://www.diyaudio.com/forums/digit...1-ess-dac.html
Vendor’s thread: http://www.diyaudio.com/forums/vendo...-se-lpuhp.html
bigpandahk’s build thread (great build pictures from page 47 onwards): Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
The GB sign up spreadsheet is here: https://docs.google.com/spreadsheet/...Xc&usp=sharing
Latest official schematic and BOM: http://www.diyaudio.com/forums/digit...ml#post2319922
Old 27th November 2013, 10:18 AM   #544
Originally Posted by bigpandahk View Post
Here is the build threads with BOM and Schematic
I don't think there is any GB for NTD1 at the moment. I have a spare kit, drop me a PM.
Thanks bigpandahk, that's helpful. And also for the kit which is now winging it's way across to the UK! I'll let you know when it arrives.
Cheers for now but I'm sure I'll have other questions ;-)
Old 27th November 2013, 06:36 PM   #545
hey crom
As I measured the height of the mosfet is thickest among them, so I made sure they have good contact with the plate.
And pad the others to the same height.
Back in the days there were a GB on parts where they got to220 size resistors from texas component which was rated 8w instead 15w in the bom.
It seemed working, you might want to try that as well.
Old 29th November 2013, 02:04 AM   #546
bigpandahk is offline bigpandahk  Hong Kong
Crom
The NTD1 generate lot of heat, you need heatsink larger than the PCB with long fins. Before you solder anything onto the PCB, use the PCB to mark the heatsink for holes.
Enjoy!!
Old 5th December 2013, 04:57 AM   #547
Need some advice on floor planning.
basic needs:
separation of ps and others
weight balancing
shortest route for i2s
Any advice?
Old 5th December 2013, 06:36 AM   #548
I'm only learning so this needs validating but here are some things that I'd do:
- keep AC away from DC,
- only cross cables at right angles (if you have to)
- You can stack toroids on top of each other if you want. You're right about the weight distribution being a problem. In one box I put transformers underneath everything and put aluminium and steel between that 'compartment' and the one above where all the pubs went.
- keep the regulators as close to the circuit you are powering ie leads short.
- twist all AC cables together, and many argue DC too...something to do with inductance if I remember correctly.
- the dac chips don't like excessive heat.
My dac build is getting so big that I am going to use 2 boxes. All the transformers, rectification and reservoir caps in one box and then regs and actual dac stuff in the other. Alternatively, you can use copper or other metal (although I never got to the bottom of which was best) to divide the box up. Keep the transformers separate, the AC out the way and then surround the pcbs with power supplies. I was also considering mounting the ntd1 upside down to get the Heat out of the top of the box. This would mean that (in the case I'm thinking about) I could put the fifo, waveio and associated digital stuff underneath the ntd1 to keep digital connections as short as possible.
There's loads of other stuff to experiment with. The lampizator guys swear by mounting their dac boards onto chunks of wood, you should definitely do this for the transformers (make sure that the mounting screws don't just go straight through wood if possible because you are trying to stop vibrations travelling from transformer to chassis). I haven't tried it with a dac board and some of their comments are ridiculed here...but then their dacs sound pretty good so I'm of the opinion that I should try before I dismiss.
Hmmm bit of a stream of consciousness that...Hope this helps,
Crom
Old 5th December 2013, 06:39 AM   #549
Don't know why you want weight balancing.
Your heatsink is too small for the NTD1. you better test it before put it into the casing.
You may following Ian's arrangement, stack the clock board on the FIFO with the SPDIF board next to the FIFO. This will provide you the shortest I2S route.
For PS, you need to separate the transformers only, not the regulators. The two SSLV also generate lot of heat, need a large heatsink.
Old 5th December 2013, 10:20 AM   #550
It's icing on the cake stuff...I'd prefer to have evenly distributed weight if I can achieve it. It's not critical though.
You're absolutely right. I looked into a heatsink. Qusp recommended a good one but it's half way around the world so I looked into others. I came up with this:
HAM-F10T TDK-Lambda | Mouser
The Thermal resistance figure is missing from the product data (believe it or not) but an estimation using some learning from this page HEATSINKS by SM0VPO indicates that it will be big enough if combined with a metal case.
Definitely don't separate the regulators from the load - they should be as close as possible to the circuit you're powering. However, the best solution would appear to be separating the transformers, rectification circuit and the reservoir caps. More info here: http://www.diyaudio.com/forums/power...een-boxes.html
Hope this helps,
Crom
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4503 Today 01:05 AM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2506 25th September 2017 02:02 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright ©1999-2017 diyAudio
