Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 23rd June 2013, 03:56 AM   #521
hochopeper is offline hochopeper  Australia
It is Si570 not i570 ...
Do you have initialisation with:
Serialx.begin(speed, config)
x is 1, 2, 3 for mega serial port num.
You can use Serialx.available() to check for data being available in the buffer.
Old 23rd June 2013, 01:42 PM   #522
bigpandahk is offline bigpandahk  Hong Kong
Yes, I am using SerialX.begin to initialize the serial port. Serialx.available sometime detects there is serial data but most of the time detects nothing. Can see data output from dual clock board Tx but Rx at Arduino always "Low" (with isolator).
Old 23rd June 2013, 11:26 PM   #523
DQ828 is offline DQ828  Australia
DQ828's Avatar
Pull Up resistors?
Old 24th June 2013, 09:58 AM   #524
DQ828's Avatar
Hmm, I have started testing the Amanero I have installed in my DAC 1 (DAC 2 BIIISE Amanero works fine) that goes via an Sidecar to the BIII and I am getting bad noise & distortion, no idea why at this stage.
Old 25th June 2013, 12:12 AM   #525
The Arduino has internal pull up resistors, I've tried to set the Rx pin to "High" and it becomes high, still not detecting any signal from the SI570!!
Amanero is quite unstable, it always gives high pitch noise when playing music, I have to unplug the USB and wait for few seconds until the noise disappear. Its SQ is not as good as WaveIO, the only advantage is playing DSD. I may try some other device if I can't fix the noise problem.
Old 16th July 2013, 01:24 PM   #526
I use two OTTO II to switch the Amanero to FIFO or BIII. When connect to BIII, it will pass through Acko's isolator board. The Amanero sound great when connected to the FIFO, but serious distortion when directly connected to BIII through Acko isolator. The only device not common to both setup is the Acko isolator, so I concentrate on trouble shoot the isolator. Spent almost two months, replaced two 74G74 and the isolator chip, the power supply to the Amanero but still no help.
Before give-up and try to source other DSD device. Last trial to connect the Amanero to BIII without isolator, the same distortion. Then confirmed the fault not isolator related.
Why the FIFO can make the Amanero distorted sound normal?
Old 17th July 2013, 05:56 AM   #527
DQ828's Avatar
I have my Amanero connected directly to the BIII & it is fine, I had issues with the grounding initially that caused noise. All wires are now straight from the Amanero to the BIII and all is good.
Old 20th July 2013, 12:53 AM   #528
Thanks DQ828
It is not grounding issue. While had no other method to isolate the problem, I turn the input selection and accidentally changed the setting of the BIII through the Arduino, all distortion went away and beautiful music from BIII
I don't know which setting had been changed.
Now, I can concentrate on the Arduino Code and hope can finish this project soon.
Old 21st July 2013, 11:13 AM   #529
DQ828's Avatar
Thanks DQ828
I had that problem
Good luck
Old 31st August 2013, 04:40 PM   #530
mcluxun is offline mcluxun  United States
Newbie check in.
Hey gentlemen
You guys are making something amazing here that I wanted to be part of.
I'm on my planning stage right now.
Which I think I need:
buffalo dac board x1
salas x1
ntd1 x1
And of course everything on the BOM.
Am I correct?
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4519 14th November 2017 12:40 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2507 8th November 2017 03:56 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 03:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 03:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
Copyright ©1999-2017 diyAudio
