Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd June 2012, 01:29 PM   #41
I received the BIII kits yesterday, a big surprise. Spent several hours for the soldering and install heatsink for the SSLVs. The most difficult part is solder 3 FL. sockets at the back of the buffalo. Finally, I have music from the BIII!!! Will connect the Arduino tomorrow.
Temperature on the SSLVs are still too high (close to 60 deg).
Old 9th June 2012, 03:21 PM   #42
Connected the rotary decoder and IR sensor to the Arduino, changed the pin assignment in the program as follow:
#define VOLUPPIN 9 // Button to increase volume or RotEnc A terminal
#define VOLDOWNPIN 11 // Button to decrease volume or RotEnc B terminal
#define SELECTPIN 12 // Switch to select function
// #define BRIPIN 6 // Pin to control the LCD brightness with analogWrite
#define REMOTEPIN 10 // Pin for IR receiver (remote control)
The selectpin function properly, remote pin can sense the signal from Apple Remote but not function as expected. No function on VolumeUP and DOWN pins. Have checked several time but still don't know what goes wrong. Can anyone give me a hand???
Connect to BIII via I2C, seems no control to BIII, how can I verify I2C output from Arduino?
Old 9th June 2012, 03:57 PM   #43
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
ermm have you set up the arduino with the correct protocols and commands to issue the hexidecimal commands to the buff III including starting with the hex/i2c address of the particular dac/s?
Old 9th June 2012, 04:01 PM   #44
I use the same code from HIFIDUINO which is for BII, which should be compatible with BIII as mentioned in other thread.
Old 9th June 2012, 04:07 PM   #45
qusp's Avatar
well maybe, that depends as being multichannel its possible they have handled it somewhat differently wrt address. hard for us to help much based on the above though tbh. how about posting your query to the man who designed the code?
Old 9th June 2012, 04:17 PM   #46
Good suggestion, will try, thanks.
Old 10th June 2012, 12:42 PM   #47
spending whole day for debugging, solve the apple remote issue, don't know why the code sent from my apple remote is different from the code from HiFiDUNIO. Now can control the volume Up / Down using Apple Remote but the Mute function still not function properly.
I also realize that Arduino Mega 2560 I2C pins are 20 & 21 instead of 4 & 5 as remarked in the program. I rewire the I2C but still can't control the BIII, use the scope to check the signal and found that signal from Arduino are pulled high by BIII. I hope it is not something failure on BIII.
Old 11th June 2012, 02:44 PM   #48
Thanks for HIFIDUNIO's advice, I solved the rotary encoder's problem. Also debugged the Apple Remote "Mute" function.
Ordered the I2C level converter. As I will use Ian's FIFO SPDIF and WaveIO as input, need further modification on the Arduino for input selection and display. Hope can receive the WaveIO and NTD1 PCB within this month, but still have no idea on the case and VFD.
Old 12th June 2012, 11:05 PM   #49
Finally, the Arduino connected with the BIII and function well. It's time to find a proper casing and decide whether use this color TFT or VFD.
Old 17th June 2012, 03:08 PM   #50
Today, I replaced all heaksinks for the SSLVs with much larger one. Before finding a suitable case for all the components, I have to figure out the best layout. After several trial, finally I come up with this as shown in the picture. I never expected I need such big size case with so many heatsink for a DAC!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 1257 Today 05:43 AM
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 2786 16th May 2013 10:22 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright ©1999-2013 diyAudio
