Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV - Page 46 - diyAudio
Old 24th January 2013, 12:10 AM   #451
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by bigpandahk View Post
Ian
All three signals, thanks.
Waveform looks perfect. Please measure them on the three diodes at the fifo board to see if signals keep same. Other wise, check up you I2S cable.
Ian
Old 24th January 2013, 12:19 AM   #452
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Originally Posted by DQ828 View Post
Is there a mini 75ohm cable/connector you can recommend to take from the to BIII SE SPDIF input to the OTTO & then on to the BNC connector that will be on the rear panel? Or should I just stick with the 50ohm
thanks for the video link
What sort of temperature are you using on the solder iron?
I personally just use a piece of regular wire, or a twisted pair from CAT5.
I use Kester 63/37 solder with NoClean flux, 0.15" diameter. (Kester# 24-6337-8806). I generally solder at about 650F. A clean tinned tip is everything.
Old 24th January 2013, 01:55 PM   #453
If you want to use the u.fl connectors, you pretty much have to use 50-ohm u.fl cables, but this should not present any issues with such short distances.
Old 24th January 2013, 01:59 PM   #454
This should be 0.015" diameter. I use this solder for all hand soldering I do.
Old 24th January 2013, 09:01 PM   #455
DQ828 is offline DQ828  Australia
DQ828's Avatar
Old 26th January 2013, 07:31 AM   #456
bigpandahk is offline bigpandahk  Hong Kong
Ian
Ian
It should not be the I2S cables as the USB through backdoor works perfect. I bypass the FIFO and connect the SPDIF directly to the BIII, it works with either USB or Optical. It seems that the FIFO does not recognize the signal from optical. Strange!!
Old 29th January 2013, 02:31 PM   #457
Ian
I believe the problem is caused by the dual clock board. It doesn't switch the sf to match the source. It always state at 96!!
Anyway, I will have the i570 to replace it.
Old 29th January 2013, 09:42 PM   #458
iancanada's Avatar
Ian
bigpandahk,
I suspect your isolator board, if there is anything wrong with the control signals, you will lost the Fs auto switching function.
Try removing it, run dual xo from FIFO directly. If it's working then the isolator board is the criminal.
Ian
Old 30th January 2013, 10:04 PM   #459
Thanks Ian
The criminal is the FPC cable from isolator to clock board.
Old 31st January 2013, 03:05 AM   #460
iancanada's Avatar
Thanks Ian
You won.
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4480 20th July 2017 06:53 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2490 17th July 2017 04:42 AM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright ©1999-2017 diyAudio
