Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 23rd January 2013, 07:15 AM   #441
DQ828 is offline DQ828  Australia
DQ828's Avatar
I'm almost scared to ask this question, here goes
If SPDIF is normally sent on an 75ohm cable why are we using 50ohm internally.
I realise that it's not just the SPDIF they are being used for.
By the way I'm getting cheaper prices (than Digikey) at Mouser for the Emerson cables & connectors if you buy in US dollars.
Old 23rd January 2013, 09:43 AM   #442
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by iancanada View Post
Please show me waveform of all three SCK and WS and SD signals form S/PDIF board I2S output port when you switch to optical input.
Ian
Ian
All three signals, thanks.
Old 23rd January 2013, 04:36 PM   #443
qusp is offline qusp  Australia
qusp's Avatar
yeah but you lose the free shipping (for $200 orders) if you do that at mouser, its a case by case basis whether its cheaper overall.
where is spdif being used on these cables? i2s is being used on these cables mostly. besides its all about the cable and the termination, not the signal
50 or even 100 ohms is used for both internal and external coax for data or instrumentation cables as well. as long as its consistent, or an appropriate transformer is used to interface 2 different types, its all good.
normally 75ohms is used for external spdif (BNC) use, with 50ohms internally, but with fifo its all i2s carried on 50ohms uBNC
Old 23rd January 2013, 07:48 PM   #444
DQ828's Avatar
I guess the question is more applicable to me as the new BIIISE I have a a place for a 50ohm connector on the SPDIF input
I didn't realise how small the suckers where until I saw the one that already on the BIIISE Ext MCLK input.
Old 23rd January 2013, 07:52 PM   #445
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
It is still terminated as 75-ohms, however.
Old 23rd January 2013, 10:03 PM   #446
SCompRacer is offline SCompRacer  United States
Yeah they are...I first ran into them when installing a wireless module in a laptop some years back.
Old 23rd January 2013, 10:59 PM   #447
qusp's Avatar
they really arent that small or difficult to deal with, guess you havent seen w.fl as used on most of the ackodacs? less than 1/2 the size
Old 23rd January 2013, 11:03 PM   #448
I made a video on how to solder them, if it's any help...
Hand-soldering u.fl connectors - YouTube
Old 23rd January 2013, 11:20 PM   #449
qusp's Avatar
good one Brian, they are easier to solder than some other parts these guys are soldering, so once the mental barrier is overcome the body and technique takes over. one thing I would say is dont use the add solder to tip, then touch to connection method, it would be too easy to get a little bit on the rim of the connector. If you do, that can be cleaned off mostly if its on the outside; with some braid and flux, but best avoided as can make the shape and thus impedance of the connection incorrect. It can also damage the cables.
also curved tweezers are recommended
flux is your friend
Old 23rd January 2013, 11:27 PM   #450
DQ828's Avatar
Is there a mini 75ohm cable/connector you can recommend to take from the to BIII SE SPDIF input to the OTTO & then on to the BNC connector that will be on the rear panel? Or should I just stick with the 50ohm
thanks for the video link
What sort of temperature are you using on the solder iron?
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
