Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 22nd January 2013, 03:06 AM   #431
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by iancanada View Post
Did you fix you s/pdif problem?
Thanks Ian
Still have no time to check the signals, will try tonight and inform you the result.
Old 22nd January 2013, 12:19 PM   #432
Checked the SPDIF with scope and all I2S outputs have signal with either USB through backdoor or optical. The frequency is much higher when input from backdoor. No data output from FIFO when switched to optical.
Attached are the SCLK signals at SPDIF output.
Old 22nd January 2013, 03:28 PM   #433
iancanada is offline iancanada  Canada
iancanada's Avatar
Please show me waveform of all three SCK and WS and SD signals form S/PDIF board I2S output port when you switch to optical input.
Ian
Old 23rd January 2013, 12:24 AM   #434
DQ828 is offline DQ828  Australia
DQ828's Avatar
Does anyone know if the pre made 50ohm coaxial cables like the ones Ian supplies can be purchased from anywhere else?
As I am not in your GB Ian I have assumed they are not available from you.
Old 23rd January 2013, 01:02 AM   #435
qusp is offline qusp  Australia
qusp's Avatar
have you tried searching u.fl ? they are everywhere
Old 23rd January 2013, 01:27 AM   #436
iancanada's Avatar
Try digikey, mouser, newark, avnet..... u.fl or ipx or ipex
Ian
Old 23rd January 2013, 01:39 AM   #437
DQ828's Avatar
Yes
I obviously searched the wrong thing previously, I assume this is what I need http://au.mouser.com/ProductDetail/H...DnsPvB9A7iY%3d
My original search came up with nothing that was in stock
Old 23rd January 2013, 01:52 AM   #438
qusp's Avatar
you couldnt have
at digikey a search for u.fl returns 229 results for cable assemblies, which I narrowed down to 24 results for suitable cables from 25-100mm long. I like the 0.81mm black cable, because it looks nicer hehe
at mouser there is a similar number, but they are more expensive. then of course there are the other compatible trade names that Ian has mentioned above.
did you perhaps not include the full stop? did you search for ufl instead of u.fl ?
Old 23rd January 2013, 02:02 AM   #439
DQ828's Avatar
you couldnt have
I don't remember exactly (late last night) but I probably made the search criteria too long & included "coaxial" 50 ohms etc
I only searched at Mouser
thanks
Old 23rd January 2013, 02:20 AM   #440
qusp's Avatar
at mouser they mostly seem to stock the hirose stuff, for double the price, you could pay for the digikey shipping with the price difference.
yeah coaxial would have returned thousands of hits, probably none of which very useful
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4660 17th May 2018 07:28 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
