Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV - Page 43 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th January 2013, 11:10 PM   #421
I measured at the BCLK output and after the resistor.
Old 9th January 2013, 02:48 PM   #422
I remeasure both clock and they both swing from 0.5V to 2.3V which should be able to trigger the FF, but still no output
Old 12th January 2013, 09:01 AM   #423
Fed a 1.9V 5MHz square wave with 2V DC offset to the CLK input of FF, output from Q. That prove all wiring correct. But still not output when connect to oscillator????
Old 12th January 2013, 03:43 PM   #424
glt is offline glt  United States
Have you measured the 3.3v supply voltage while playing music?
www.hifiduino.wordpress.com
Old 13th January 2013, 02:02 AM   #425
I've measured the 3.3V and found very high level noise. Followed your Mod and added two capacitors at the input of the LDOs. Noise reduced significantly and SQ also improved. But the FF still not work
Old 13th January 2013, 05:54 AM   #426
Good to hear about the caps. But sorry to hear that the FF is still not working. Have you measured the clocks without the FF connected? There is no way the clocks have such low voltage if VDD is 3.3v
Old 13th January 2013, 06:02 AM   #427
qusp is offline qusp  Australia
qusp's Avatar
Might I suggest you get one of acko's amanero isolator/reclocker PCBs
Old 13th January 2013, 07:06 AM   #428
Thanks, just added my name in the GB list.
Old 13th January 2013, 07:07 AM   #429
The clocks are the same with and without FF
Old 22nd January 2013, 02:08 AM   #430
iancanada's Avatar
Did you fix you s/pdif problem?
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2377 Today 12:31 PM
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4421 Today 08:32 AM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright 1999-2017 diyAudio
