Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 7th January 2013, 04:06 AM   #411
hochopeper is offline hochopeper  Australia
8ch of any IV is going to get big and complex, fast.
It's the heat of the NTD1 that is a really big issue for multichannel, ask qusp how he's going with his 4ch of NTD1
Old 7th January 2013, 04:10 AM   #412
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
And I'm aiming for 16
Adrian
Old 7th January 2013, 04:17 AM   #413
Sounds fun!
I have thought long about trying to build a multichannel active system with 4 way fronts, 3 way centre, 2 way rear all active. Trust me, its not a way to save money but would be fun!!
Old 7th January 2013, 04:19 AM   #414
If i DIY it in $15K what a processor would cost i can build it all myself
PS:
I already have started... both ADAU1445 and ADAU1966 are in the Eagle Parts library
Next is waiting to hear back about the CS497024 samples, meanwhile I'm going to draw up a schematic for the DSP/DAC all on 1 Board
Adrian
Old 7th January 2013, 04:38 AM   #415
With ADAU1966 you don't need any IV
Old 7th January 2013, 04:54 AM   #416
qusp is offline qusp  Australia
qusp's Avatar
As good as the ESS is, if going for 16 channels and was diying the design, I would probably just be using 2 x multichannel digital input class D amp, or multichannel voltage output dacs. 16channels of IV is just a pita
just the transistor matching for 16 channels of legato is significant work. also IMO, just stick with opamps, honestly the legato sounds like one =) because it basically is one.
Old 7th January 2013, 02:15 PM   #417
bigpandahk is offline bigpandahk  Hong Kong
I follow HiFiDUINO to mod the clk of AmaneroAmanero USB Synchronous Reclocking H i F i D U I N O
The only different is I use 47R instead 220R connecting to the oscillator. No output at the Potato 74 FF. All the wiring are correct and when I connect the CLK pin of 74 to Vcc, Q has output. Seems the swing of the oscillator level is not enough to trigger the 74 FF. Can anyone advise what goes wrong?
I've tried 100R and 1K resistor and got the same result.
Old 7th January 2013, 05:10 PM   #418
glt is offline glt  United States
Is you VCC 3.3V?
According to spec, you need at least 2V in the signals to trigger...
www.hifiduino.wordpress.com
Old 7th January 2013, 10:01 PM   #419
VCC is using the 3.3V on Amanero. My scope shows both Bclk and oscillator output only have 1.64V.
Old 7th January 2013, 10:35 PM   #420
How can that be? The clocks operate at 3.3V and output should be at least ~ 3.0V. Are you measuring the clocks at the input of CPLD?
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
