Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 3rd January 2013, 11:22 PM   #401
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
Originally Posted by bigpandahk View Post
Yes, those are AC.
See here INTRO H i F i D U I N O you will have most of the information.
I modified the code to include the power on/off function. DQ828 had demonstrated how to control the backlight LED Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Great !!
Thanks for the info
Now to do a lil research...
Thinking ipod interface and/or HDMI switch with that will allow me to pull the spdif stream. There's a few available on ebay and could most likely make it work with the HiFiDuino
If i do go with the switch option then I will opt for the 8Ch version of the BIII and 4x Legato's set up for balanced and single ended mode
Adrian
Old 6th January 2013, 08:30 AM   #402
bigpandahk is offline bigpandahk  Hong Kong
Test the Amanero again, thanks for syklab borrows his Amanero to me so that I can confirm all the wiring and setting are correct.
My Amanero suddenly come to alive again. I resolder the Mod to Amanero, but no sound when using the re-clocked BCLK. Check TTL level at all the 74 pins and confirmed pin 1, 4 and 14 are Vcc, pin 7 to gnd, pin 2 & 3 have clk, but not output at pin 5 & 6.
Since both the BCLK and clock signal from oscillator are not TTL, how can the 74 work?
Old 6th January 2013, 05:59 PM   #403
primary 2x115V Secondary:6V 1.25A x 2, 12V 1.25A x 2, 5V 1A x 4, 9V 1.5A x1
I just thought of this...
Wouldn't be easier to have 2 separate transformers ??
The digital circuits fed from 6VAC and regulated to 5VDC and 3.3VDC.
The analog I/V Stage fed from 15VAC and regulated to 15VDC
This way the digital circuits can stay on and put into "sleep" mode while the analog line stage can be all together turned off.
Adrian
Old 6th January 2013, 06:10 PM   #404
qusp is offline qusp  Australia
qusp's Avatar
its never easier to have 2 transformers in a build of this size/complexity
Old 6th January 2013, 09:32 PM   #405
Last time I called for a custom toroid to get would for my monoblocks i was qouted $1200 / Toroid !!!
Hence, from that point on I always tend to use off the shelf units.
The units i was going to use are from Antek are AS2215 and AS1206.
A bit overkill for stereo setup, but to power multiple I/V sections and headphone amp for the bipolar supply, and for the rest of the digital and analog 5V supplies will be split. Separate regulated 5V and 3.3V supplies will be fed analog and digital sections.
Adrian
Old 6th January 2013, 09:52 PM   #406
Yes, The custom toroid is for digital circuit and have another two from Antek for the NTD1, but you are correct that I need another one just for the Arduino.
Custom made toroid in China is much cheaper and with good quality. You can even custom R-core transformer.
Old 6th January 2013, 09:54 PM   #407
hochopeper is offline hochopeper  Australia
Adrian,
We had a similar discussion a while back. If you have a look around post #305 in this thread you might find some discussion of interest
The point is that for the NTD1 alone there are 2 x antek transformers you would need. Then separate secondary + regulators for each critical sub-circuit you can easily end up wanting far more than 4 secondary windings. For low power stuff a custom unit is no where near the price you're indicating and if you try to use 3 to 5 transformers you quickly end up with trouble fitting the little critters neatly into any reasonable enclosure.
Chris
Old 7th January 2013, 02:59 AM   #408
Whats NTD1 ??
I googled it and found nothing on it...
Adrian
Old 7th January 2013, 03:02 AM   #409
NTD1 is an IV stage - it is a design by opc based on the Pass Labs D1 New Take D1 became NTD1.
Its power supply is full dual mono and uses 1 secondary per 'phase' of the balanced signal.
It has a thread here - http://www.diyaudio.com/forums/digit...1-ess-dac.html
Old 7th January 2013, 03:36 AM   #410
Ummm...
No thanks LOL
Most likely will end up using the Legato Schematic, but instead pile 8Ch onto one larger board.
I'm attempting to have all 16ch wired up and functional for Balanced and SE outputs. 2ch will draw about 500mA, so 8ch will draw about 4x that... A whooping 2A !! and for 16ch should be about 4A !!
Anyways..
I'm gonna stop littering this thread and Start my own..
Adrian
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2587 18th April 2018 09:45 PM
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4651 10th April 2018 11:51 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
