Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 3rd January 2013, 05:43 AM   #391
qusp is offline qusp  Australia
qusp's Avatar
no it wont work without the clock board, where would it get its clock....
it still needs to take a clock from the single clock board for operation, you can take the i2s directly from the fifo board, which simply means you get an output with the jitter of the clock + the jitter of the FPGA, taking the output from the clock board means its taking the output from the fifo board and reclocking it, meaning the jitter is that of the clock itself, plus the jitter of the flipflop/clock buffer
Old 3rd January 2013, 06:03 AM   #392
karvid is offline karvid  Sweden
karvid's Avatar
Sorry I wasn't so clear.
Yes, I mean with one of the clock board connected, but the I2S signal taken directly from the Fifo board. But as you say I don't get any advantages with this. So I have to wait for a working dual clock then.
Old 3rd January 2013, 07:57 AM   #393
necplusultra is offline necplusultra  Canada
I know this sounds too simplisitic but I had a similar problem before I realized that the clocks were not well inserted into their sockets.If I recall, I think they were even inverted.
You can also check that the voltages are correct on the clock board.
Old 3rd January 2013, 07:59 AM   #394
qusp's Avatar
yeah I get the feeling this is going to be one of those Fonzie moments
Old 3rd January 2013, 08:03 AM   #395
Another simiar problem I had was that my salas shunt was not givng enough current for the fifo and clock board. It was also powering the subu dac. Gave more current and all was fine.
Old 3rd January 2013, 08:56 AM   #396
qusp's Avatar
5v is a bit low too
Old 3rd January 2013, 02:04 PM   #397
karvid's Avatar
I just checked the clock and the legs are well inserted and in correct orientation.
I tried to rais the voltage to 6 VDC and it didn't make any different. The voltage to both clocks is 3,286 VDC in both cases (5VDC or 6VDC in) and the same for both clocks.
Old 3rd January 2013, 02:11 PM   #398
karvid's Avatar
Forgot..
I also checked the frequency setting jumpers and they have the correct setting according to manual.
Old 3rd January 2013, 09:13 PM   #399
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
Originally Posted by bigpandahk View Post
primary 2x115V Secondary:6V 1.25A x 2, 12V 1.25A x 2, 5V 1A x 4, 9V 1.5A x1
I use encoder for volume control
I assume those are AC not DC.
What type of encoder are you using ??
I was looking at 2 push type... one for volume control with push to mute and the second would have been source selection and on/off, however I think that would require the adruino to be on constantly and would have to figure out how to kill the display back lighting then.
Adrian
Old 3rd January 2013, 09:51 PM   #400
bigpandahk is offline bigpandahk  Hong Kong
Yes, those are AC.
See here INTRO H i F i D U I N O you will have most of the information.
I modified the code to include the power on/off function. DQ828 had demonstrated how to control the backlight LED Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
