Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 2nd January 2013, 10:15 PM   #381
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by karvid View Post
I have now tryied to connect all the ground wires and it did not make any different.
Still very quiet despite everything looks ok.
OK, Now I suggest
1, Connect the BII directly to the FIFO board I2S output port rather than the clock board to see if it's working
2, replace the double xo clock board with the single xo clock board (with onbord 11.2896 xo) , play 44.1K audio to see if there is sound.
Good luck.
Ian
Old 2nd January 2013, 10:35 PM   #382
karvid is offline karvid  Sweden
karvid's Avatar
Yes, Yes, Yes...!!
It plays sweet music without the dual clock bord and also with the single clock board!!
So the problems seems to be the dual clock board.
What can be wrong with the dual board?
Old 2nd January 2013, 11:06 PM   #383
karvid's Avatar
Ian,
I just noticed that it does not play or let the I2S signal go through to the BII dac without the 10-pin FPC/FFC cable connected to a clockboard. But perhaps it exchanges some signal necessary for the Fifo board.
Good night !
Old 2nd January 2013, 11:09 PM   #384
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by Adrculda View Post
I'm keeping my eye on this thread, as I am too planning a similar project in the near future and want to draw as much wisdom/info as I can out of this thread to simplify my own build :P
Welcome to the party Adrain.
Old 2nd January 2013, 11:57 PM   #385
iancanada's Avatar
Ian,
Good night !
Congratulations, Karvid!
Yes, the FPC/FFC has control signals inside, so, it won't work without it.
Ian
Old 3rd January 2013, 01:04 AM   #386
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
SO...
What toroid are you using bigpandahk ??
I work in a machine shop now and have access to quite a few machines and can mill my own case :P
Ordered the TFT and the DUE today
Ooooooo and it's the 5" ( 800x480 )
Adrian
Old 3rd January 2013, 03:54 AM   #387
I ordered the toroid from China who has very good reputation in custom made toroid for DIY. The 80VA cost me US$50.
Old 3rd January 2013, 04:00 AM   #388
What are the voltages if you don't mind me asking..
Also,
Are you using a pot or encoder for volume control ??
Adrian
Old 3rd January 2013, 05:22 AM   #389
primary 2x115V Secondary:6V 1.25A x 2, 12V 1.25A x 2, 5V 1A x 4, 9V 1.5A x1
I use encoder for volume control
Old 3rd January 2013, 06:32 AM   #390
karvid's Avatar
Thanks Ian,
will the jitter eating Fifo work even without the clock board?
I could then for the time being play without the clock board all my 192kHz files. With the single clock board I will be rather limited.
But what about the dual clock board?
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2561 12th February 2018 02:38 PM
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4593 11th February 2018 03:26 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 03:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 03:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
