Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 1st January 2013, 06:26 AM   #371
bigpandahk is offline bigpandahk  Hong Kong
Test the modified Amanero but failed. No sound
No BCLK output even at the Amanero. Since the Amanero output has resistor, should not be that easy to be damaged.
May be have to order another one
Old 1st January 2013, 06:38 AM   #372
qusp is offline qusp  Australia
qusp's Avatar
what samplerate did you test? remember that this mod may not work with 352.4/384
Old 1st January 2013, 08:13 AM   #373
Just playing 44.1K. I erased and reloaded the firmware, BCLK appear again but still no sound.
Old 2nd January 2013, 02:50 AM   #374
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
I'm keeping my eye on this thread, as I am too planning a similar project in the near future and want to draw as much wisdom/info as I can out of this thread to simplify my own build :P
Adrian
Old 2nd January 2013, 05:10 PM   #375
karvid is offline karvid  Sweden
karvid's Avatar
Hi all,
I am stuck with a problem I hope someone can help me with.
After connecting my Fifo to my M2Tech Hiface evo (I2S output), my BII at the outlet of the dual clock and powered the Fifo with 5VDC. Everything looks ok but it doesn't play music, just silence.
My connection with Hiface evo.
M2Tech Hiface evo out: → Fifo in:
2,4,6,8) Ground → GND
1) SDATA → SD
3) LRCK (FS) → WS
5) SCLK (BIT CLOCK) → SCK
7) MCLK (Not connected)
My connection to BII.
Dual clock out → BII in:
Gnd → GND
SD → D2
WS → D1
SCK → DCK
MCLK (Not connected) since I uses the BII clock.
The fifo LED’s work perfectly and they seems stable. But no music comes out.
When connected and music played the Fifo led indicate locked signal. If I disconnect input signals and the led give the correct respons (the led goes black). The strange thing is that the led for Fifo buffer empty lights up (stable) even when music is played.
On the BII the led indicates that a signal has been locked and everything looks ok.
On the clockboard led for 512 and 44,1 kHz is shining.
You will find a manual on how to use I2S for M2Tech Hiface evo here: http://user.tninet.se/~pst442t/hiface_evo_i2s.pdf
The manual for Buffalo II here: http://user.tninet.se/~pst442t/Buffa...anual_v1.0.pdf
Greatful for all help I can get!
For info: My BII plays perfectly if the signal goes directly from Hiface to BII.
Old 2nd January 2013, 05:35 PM   #376
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by karvid View Post
Hi all,
1) SDATA → SD
3) LRCK (FS) → WS
Gnd → GND
SD → D2
WS → D1
SCK → DCK
The fifo LEDís work perfectly and they seems stable. But no music comes out.
Hi Karvid,
Can you post pictures of your hookup?
Thanks,
Ian
Old 2nd January 2013, 06:22 PM   #377
karvid's Avatar
I add som pictures of my setup.First picture without inlet and outlet connected and in the second it is connected and powered up (trying to play music).
Note only one of the super shunt regulators is used.
Sorry about the format. I do not now how to make mini pictures..
Old 2nd January 2013, 07:38 PM   #378
iancanada's Avatar
Picture is OK.
It seems that the 7Pin PH2.0 I2S bridge cable connector on the clock board side has a bit loose. Can you confirm?
Ian
Old 2nd January 2013, 07:59 PM   #379
karvid's Avatar
Ian,
I have double checked all connectors. And they seems all to be well connected. As well as the clocks.
After som handling has the led for empty buffer gone out (doesn't shine any more).
But if I disconnect the signals the Led says no longer locked signal and the buffer is empty. When I connect signal the led for locked signal is shining bright again and the buffer doesn't say emty any more (neither say the led that the buffer is full). So according to the led everthing is working.
This might be because I connected all of the gnd cables at input. I will try to do the same at the outlet and see if this will make a different.
Old 2nd January 2013, 08:29 PM   #380
karvid's Avatar
I have now tryied to connect all the ground wires and it did not make any different.
Still very quiet despite everything looks ok.
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
