Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 3rd December 2012, 02:50 PM   #331
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by qusp View Post
I know that....
its easy enough, easier than what you are trying to do, which would seem to require you to change to an entirely different interface to play DSD. you only need to use OE pin on amanero to switch left and right for DSD (if that is still an issue, not everyone has this problem) PCM and DSD share the same pins. use OE to trigger different DSD filter on ESS if need be as well.
I think its an easier way forward than having 2 interfaces.
Using one USB input device is much better than two, at least no cable switch
I may use one OTTO to switch the output of Armanero to FIFO or direct to BIII another OTTO at the BIII input to select FIFO or Armanero (through OTTO 1).
Old 4th December 2012, 08:09 AM   #332
DQ828 is offline DQ828  Australia
DQ828's Avatar
I apologise in advance if I've missed this in the thread somewhere.
How are you planning on powering the Amanero, from the USB input?
Old 4th December 2012, 08:16 AM   #333
You haven't missed this, I haven't decided yet. My present thinking is to remove the L1 on Amanero and power the on-board regulator by SSLV or Ti TPS7A4700 with an I2S isolator for the output.
Old 5th December 2012, 08:33 AM   #334
DQ828's Avatar
"with an I2S isolator for the output" At the output of the what? the Amenero? , sorry I am learning?
What will the I2S isolator do for you?
Old 5th December 2012, 10:17 AM   #335
qusp is offline qusp  Australia
qusp's Avatar
DQ828, you were asking about pics, I dont have that many, but I posted some over at SNA in crazyfrog's 'my new DAC' thread
the isolator cuts the ground connection. pollution on ground has a noticeably negative effect on dac performance, with ESS particularly, using a USB->i2s convertor you create a direct link to your PC ground and thus link signal ground wit your PC ground, not good, it causes more than just jitter.
the isolator galvanically isolates the i2s output, cutting the ground connection. it adds some jitter in this process, but the best ones not so bad and its probably the lesser of 2 evils. when using the i2s fifo this has no effect since its before the reclocking stage, so only the DSD output of amanero will be affected in BPHK's DAC
Old 5th December 2012, 04:19 PM   #336
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Could you please post link for the pictures? I do not know what is SNA.
www.burningamp.com
Old 5th December 2012, 09:59 PM   #337
qusp's Avatar
you will have seen them before AR2 probably, its just a few old pics because I was asked. its a smallish Australian forum StereoNET Australia. heres the thread
just various testing photos, nothing final, I dont have a case that fits it all and in those pics i'm still testing out various interfaces and IV stages.
Old 6th December 2012, 05:58 AM   #338
DQ828's Avatar
There's a lot of action in that case
Old 6th December 2012, 06:00 AM   #339
DQ828's Avatar
What isolator are you using?
More things to fit in the case
Old 6th December 2012, 06:04 AM   #340
qusp's Avatar
its only about half there in any one of those, none have more than 2 channels final format will have 4 or 6 channels. I have 4 built up, thinking of adding one of Acko's es9016 boards for sub/bass
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4660 17th May 2018 07:28 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
