Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV - Page 33 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th November 2012, 08:54 AM   #321
Originally Posted by DQ828 View Post
I mean for the transformer Secondaries
If we're talking overkill (or in qusp's words, modern ES9012 DAC) you will have independent power supplies for each of the following:
- ackodac supply inputs.
- usb (I think qusp has 2 supplies for his usb device, the rest of us are ok with just 1 )
- FIFO
- FIFO oscillators after isolator
- 4 of secondaries just for NTD1 line stage, one secondary for each phase of the balanced signal
- some control circuits for arduino/lcd/whatever else
This gets somewhere in the order of 15 odd supplies. And remember he is building two of them and building two way speakers with crossover in the computer and multichannel usb device.
NB. By independent I mean: separate battery(s) or tx secondary, rect, pre-reg + low noise local reg to go with appropriate local decoupling and EMI filter
In my case I have ES9023 (AKD23) with only one power supply to the DAC chip and still 6 tx secondaries and I am considering adding another 3 or 4 in another transformer. I think for this transformer I might grab an EI core tx from Harbuch with one 8V and one 32V ct secondary to power jfet DAC output filter/buffer and use the 8V with an LM317 for my beaglebone (arm linux pc for control and music playing).
Old 30th November 2012, 02:07 PM   #322
qusp is offline qusp  Australia
qusp's Avatar
I know what you meant =) hochopeper covered my answer pretty well.
I didnt have a drawing anyway =) sorry its not deemed essential equipment yet, so I havent worried about it too far, plus its tiny and could go anywhere. thats not a comment on the quality, it'll find a place somewhere, but not in the main system as its only 2 channel. I bought it to experiment with DSD and in particular to experiment with direct analogue active filtering of DSD, with no DAC, or rather Amanero becomes the dac and a filter + buffer is added to listen directly
Old 30th November 2012, 08:15 PM   #323
DQ828 is offline DQ828  Australia
DQ828's Avatar
- FIFO
I can see qusp has a problem with power
Is there photos around of this beast.
ATM I have 2 x trans for the Buffalo & 1 x SMPS for everything else.
Old 3rd December 2012, 02:41 AM   #324
In addition to the power supply arrangement for so many devices, another headache is switching between inputs. I have the Amanero DSD convertor, WaveIO, Teleporter and Ian's SPDIF. The WaveIO will be connected to the backdoor of SPDIF and still have three different sources to be connected to BIII. Although I have the SideCar and OTTOII, I can't figure out how to switch between three I2S source with them.
There is no 3 ports 4:1 Mux product available. All I can find is the Potato PO3B341 that perfectly match my requirement but I don't have the knowledge to layout the PCB for it
Old 3rd December 2012, 07:17 AM   #325
qusp's Avatar
why do you need waveIO and amanero? just stay with amanero, combined with fifo you will find it impossible to pick a difference, you only need to work out switching from amanero PCM and amanero DSD. you have a far too complicated signal path above, very unnecessary.
Old 3rd December 2012, 11:03 AM   #326
BrianDonegan's Avatar
Add a second OTTO. Feed the output of the first into one input of the second. We've talked about a 4x4:1 mux, but didn't think it would be too commonly needed.
Old 3rd December 2012, 02:25 PM   #327
As Ian's FIFO doesn't accept DSD stream, it is not easy to switch between Amanero PCM and DSD. That's the reason to use both WaveIO (PCM) and Amanero (DSD) for USB source.
Old 3rd December 2012, 02:28 PM   #328
I've considered this one but there are too many switching devices in the signal path, 2 OTTO + 1 SideCar
Old 3rd December 2012, 02:31 PM   #329
qusp's Avatar
I know that....
its easy enough, easier than what you are trying to do, which would seem to require you to change to an entirely different interface to play DSD. you only need to use OE pin on amanero to switch left and right for DSD (if that is still an issue, not everyone has this problem) PCM and DSD share the same pins. use OE to trigger different DSD filter on ESS if need be as well.
I think its an easier way forward than having 2 interfaces.
Old 3rd December 2012, 02:36 PM   #330
It's just digital, not analog.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4403 Yesterday 09:22 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2374 Yesterday 02:02 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Copyright 1999-2017 diyAudio
