| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#261 |
After installed Ian's isolator board, the bass become much clear and powerful. I am waiting for the i8605 for the additional isolation on the I2C bus.
Today, receive the battery management board and will assemble it ASAP. Unfortunately, my DAC has a new problem, actually it should be old issue but happen more frequent. When I used the Legato for couple of days, I found its temperature is abnormally high. Some resistors reach 75 deg. C after 20-30 minutes operation. I have raised this query in the TPA support forum but was told it is normal. Now, I believe the high temperature already damage some component(s). Last month the Legato start to fail after couple hours, but now it can only survive for several minutes. Both channels have no sound when fail, any suggestion to trace the problem? Please!! |
#262 | |
. As well as the isolator board. I'm afraid you may need the pull-up resistors for the I2C buses if they were not included on both DAC and controller side.Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#263 |
is choosing a less facetious title...
solution, use a proper IV stage =P not long to wait now
#264 |
Hello bigpandahk,
I just grabbed my cheap rigdgid 'microray' IR temp reader and I'm looking at close to the same as you. I'm getting ~155-165 degrees F which on the higher side ends up very close to your 75C reading. I 'shot' the resistors along VR1+2 on both of my legatos. One was about 10-15 degrees warmer. I'm feeding these ~14.8 volts from the placid BP supplies. So far, they still play and sound WONDERFUL. Just for kicks I 'shot' my placid heatsinks, which are the taller ones on Leon's BOM and they were around 140-150F. sorry for not much help. I'm still wrestling with my arduino control. /mike |
#265 |
those resistors are too close to each other so they warm each other up. One solution was to put the middle one on the bottom of the board... and to elevate them away from the board so they get more air through... (I have not built mine yet so it is all head knowledge :-))
www.hifiduino.wordpress.com |
#266 | |
Thanks for your advice. |
#267 |
#268 | |
#269 | |
#270 | |
If you haven't started your build yet, I'd highly recommend stacking boards where you can, ie input board, sidecar, etc. Saves space besides the extra wire. /mike |
| Ian asynchronous I2S and S/PDIF FIFO KIT group buy | iancanada | Group Buys | 1258 | Today 04:56 PM |
| Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter | iancanada | Digital Line Level | 2786 | 16th May 2013 10:22 PM |
| FS Quanghao SSLV Salas design | merlin el mago | Swap Meet | 12 | 17th August 2012 02:06 AM |
| F.S quanghao salas sslv 1.0 for buffalo dac. | back | Swap Meet | 1 | 31st July 2012 02:32 AM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
