Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Old 12th October 2012, 10:05 PM   #231
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by glt View Post
Very nice!
I too had some problems with the remote when using analog write. I was not able to find the reason, so I gave up controlling the brightness with the Arduino and used a manual pot. It is possible, the pulsating LCD is creating a lot of noise and interfering with the IR sensor. I documented some issues here: Apple Remote Control for Buffalo II DAC H i F i D U I N O
BTW, what are those small orange boards?
Thanks, I'm glad it's not just me.
The orange boards are Tinkerkit Mosfet relays, they are switching the relays I had already installed into my amp & DAC.
Old 13th October 2012, 01:25 AM   #232
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by DQ828 View Post
Pin 19? must be a different screen, mine is pin 37
We are using the same screen, look at the marking of the board, your pin no should be 19.
Old 13th October 2012, 06:19 AM   #233
DQ828's Avatar
Yes you are right, I was forgetting how the numbers went
Old 13th October 2012, 06:27 AM   #234
Removed the pin connecting LCD screen and Arduino Shield, solder a 47ohm resistor in series and connect to PWM pin. Screen dimming and off are working fine. Other functions including remote are working as expected. Number of relays increase from 2 to 6 and seems still not enough
Old 13th October 2012, 06:38 AM   #235
Yeah, I am most interested in this bug :-). The way it is currently programmed (as dimdim said) is that every input has independent settings for each function, and they are saved in eeprom. When you switch to another input, the settings are recalled from the eeprom and programmed into the registers. Granted, not all of the them would change, but it was easiest to just rewrite all the values into the registers everytime you change inputs.
I go through the original HiFiDuino's code again and have a different view. There is no specific format for each input, you just have to assign a name for it. So it is not possible for the code to know whether input #1 is SPDIF, PCM or DSD. The code only read the SPDIF status register to determine whether the source is SPDIF or DSD.
Old 14th October 2012, 05:53 AM   #236
I successfully modified the BIII to run in synchronized mode with FIFO. The sound is lot more dynamic with more details. Thanks Ian.
But Synchronize mode cause a new problem, Arduino can't display the correct clock frequency
Old 14th October 2012, 05:56 AM   #237
hochopeper is offline hochopeper  Australia
Where are you determining fs? For waveio you can use its output header...
Old 14th October 2012, 06:24 AM   #238
syklab is offline syklab  United States
Like your setup with Ardunio.
Old 14th October 2012, 06:26 AM   #239
HiFiduino's code read the register in the BIII and then divided by an integer which was calculated based on the crystal frequency. I am not sure whether Ian's clock board output fixed frequency or will be changed based on the SF of the source
Thanks for your suggestion, but it only indicate the frequency when using USB:-(
Old 14th October 2012, 08:07 AM   #240
qusp is offline qusp  Australia
qusp's Avatar
cant you still read the register on the BIII? fifo MCLK is fixed frequency (1 or 2 depending on if you are using single or dual clock board) the BIII will use BCLK which changes with FS, not MCLK I would think. the info presented to the BCK pin on ESS will be the same whether you use the onboard clock, or fifo in sync mode
Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLVHide this!Advertise here!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4661 7th June 2018 08:35 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 02:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 02:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
