Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV - Page 18 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th September 2012, 10:10 AM   #171
DQ828 is offline DQ828  Australia
DQ828's Avatar
I have sent the code & the raw files good luck
Old 19th September 2012, 04:18 PM   #172
Thanks DQ828, I received the files and tested, but no success.
I think the problem is related to the file structure in the SD. Thanks a lot for your help and effort.
Old 19th September 2012, 07:20 PM   #173
Hi bigpandahk. I've been following your progress (along with DQ828 and Corpius). I have a dual mono BIII with 4 input S/PDIF board and Sidecar mostly complete (want to add USB input). I was designing a case when I saw the Arduino with LCD displays and had to have one...hopefully...lol
Old 20th September 2012, 02:05 AM   #174
Hi SCompRacer
I am also following your BIII project and your connection to the DVD player is great. I will use OTTO 2 and teleporter to connect a DSD sourse and is searching a suitable DVD player.
Old 22nd September 2012, 04:34 PM   #175
Hi DQ828
Finally, I manage to display the Bitmap files. The problem is the SD card must not be a MicroSD with adaptor. I hardly find an old SD card and have your bitmaps displayed on the GLCD.
Thanks again for your help and efforts.
Old 23rd September 2012, 09:12 AM   #176
This project is far complicate than expected. Just find the best way to connect all the modules is not easy. Thanks for Ian's I2S backdoor which make my life much easier.
I still can't figure out how to switch between PCM and DSD signal since BIII requires different jumpers. According to TPA, SideCar should be designed for this purpose but after checking the details, it can only switching between 4xSPDIF and I2S.
The TTL input of Ian's SPDIF also can't work with the USB WaveIO. Since I don't have another SPDIF source and can't identify which part causes the problem.
Ian's FIFO can't read DSD stream, therefore DSD will go direct to BIII (if I can sort out the jumper problem) and switched by either SideCar or OTTO 2.
BIII + Legato will be powered by SSLV, FIFO + SPDIF + Clock will be powered by 2 x LiPO. I am still thinking how to power the WaveIO by LiPO since it need to drop 1.4V. May be use two diodes!
Old 23rd September 2012, 03:06 PM   #177
Can you say Audio?
All you need to do, is place jumpers for DSD - and you can send both PCM and DSD to the pins with no worries. I've done something similar (eXD board, DSD pins to Otto, I2S pins to FIFO to Otto, Otto to Buffalo III with DSD jumpers set.
Works like a champ!
Old 23rd September 2012, 03:27 PM   #178
Thanks MisterRogers
You save me lot of time.
Old 26th September 2012, 04:03 AM   #179
Just got the reply from Russ on jumper setting:
Stereo DSD and Stereo PCM?
There is no need to switch anything.
Even without sidecar You just need to:
connect D1 to D5
then D2 to D4 and D6
then D3, D7 and D8 to GND.
Now nice thing... the Sidecar module does this for you when PCM/DSD input is selected.
Old 28th September 2012, 04:17 PM   #180
connect the SideCar to BIII and check the pin connection. It is different from what Russ mentioned. Only find the following connections are done by SideCar:
D1 to D5 (DSD1)
D2 to D6 (DSD2)
D7 and D8 to GND.
D3 and D4 are not connected to anything by SideCar.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter iancanada Digital Line Level 4328 Yesterday 01:45 PM
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2235 17th January 2017 11:26 PM
FS Quanghao SSLV Salas design merlin el mago Swap Meet 12 17th August 2012 03:06 AM
F.S quanghao salas sslv 1.0 for buffalo dac. back Swap Meet 1 31st July 2012 03:32 AM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
Copyright 1999-2017 diyAudio
