Redbook CD/SPDIF clock tolerance spec ?
Old 14th May 2012, 05:32 PM   #1
percy is offline percy  United States
Default Redbook CD/SPDIF clock tolerance spec ?
Somewhere on the net I read that the Redbook CD (or is it SPDIF?) has a clock tolerance specification of 12UI. But I can't find any further definite information about this spec.
Is this true ? And if so what exactly does this mean ? 12UI per second ? per million UIs (ppm) ?
And is it really a Redbook CD spec or an SPDIF spec ?
Old 14th May 2012, 06:41 PM   #2
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
UI = Unit Interval. A Unit Interval is one way to specify jitter. One UI = the period for one data bit in serial data channel. So, it is not a constant and varies with the data rate. For example, one UI for a typical 2.8224Mbs CD digital audio stream = 354ns. I don't know what the rebook spec. calls for, but I believe they would be specifying maximum permissible jitter.
Redbook CD/SPDIF clock tolerance spec ?Hide this!Advertise here!
Universal 1ppm CD clock + SPDIF isolator low jitter dublin78 Digital Line Level 10 30th April 2012 12:24 PM
Proven: Good Old Redbook CD Sounds the Same as the Hi-Rez Formats ashok Digital Source 2 30th October 2007 02:53 AM
Jupiters: Tolerance: 26% over spec: o.k.? boneshaker Tubes / Valves 1 26th April 2006 07:48 AM
Sony SCD-555 problems with redbook CD Jan Deckers Digital Source 4 1st August 2004 09:08 AM
Where can I get the spec. of the I2S and SPDIF standard ? intuit Digital Source 0 4th March 2004 07:45 AM
