simple discrete dac output stage anyone? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th May 2012, 05:30 PM   #1
rmgvs is offline rmgvs  Netherlands
Default simple discrete dac output stage anyone?
Who has experimented with a simple discrete output stage voor a DAC instead of using an opamp like NE5532? For example: the so-called 'Gator' boards which can be plugged into a Beresford Caiman: it uses 2 small signal transistors and a handful of components, it amplifies around 2-3 times and has a small amount of feedback. I can't find the schematics on the net though, but it can't be too hard to make something of this. It is meant to be put after the Wolfson WM8716 dac.
Another example is the fetishizator from Fikusz and others: it uses 1 or 2 (with or without impedance buffer) small signal fets, but I think it has a higher amplification factor.
Has anyone tried some variants for himself and compared it to a normal or good opamp? Which topology is recommended (I am looking for one after the Wolfson WM8740). Any suggestion is welcome.
Can the PCM1794 better the PS1's sound? (or: alternative DAC w/ simple output stage?) sfasf Digital Line Level 14 24th January 2012 08:20 PM
About discrete I/V stage circuits for a TDA1541A dac gaetan8888 Digital Line Level 5 11th December 2010 07:28 PM
Discrete DAC i/v stage bocka Digital Source 20 28th May 2010 05:05 AM
Borbely Discrete Analog stage for DAC or CDP regal Swap Meet 6 18th July 2008 12:25 PM
Discrete output stage for Sony c222? Sheldon Digital Source 17 26th December 2004 08:44 PM
Copyright 1999-2017 diyAudio
