Output impedance of a DAC analog stage
Old 6th May 2012, 09:42 AM   #1
atupi is offline atupi  Romania
Default Output impedance of a DAC analog stage
Could someone tell me what is the output impedance of this analog stage and maybe how can be calculated ? Click the image to open in full size.
I'm asking this because when i'm testing my B1 buffer with my 100k input impedance amplifier sounds better if i put the buffer before my volume pot even if everyone is recommending to have buffer after the volume pot and i suspect something wrong with output impedance of this analog stage of my DAC.
With the buffer after volume pot the bass and stereo image is ruined.
Instead of LT1028 i'm using LME49720.
My volume pot in 20k log.
Old 6th May 2012, 10:11 AM   #2
wwenze is offline wwenze  Singapore
The above stage's output impedance is dominated by the value of R7, so it's just a bit higher than 100ohm.
Old 6th May 2012, 10:51 PM   #3
martin clark is offline martin clark  Europe
+1 to that; and by 'just a bit' as wwenze refers you should understand that as 'only a few tens of ohms, plus R7, in the audio band'. The excess mostly depends on the exact opamp chosen for U3, but even a poor choice will be well within 100R.
So this analogue /filter stage will be perfectly happy driving your 20K pot on its own and. I think you may need to review what is going wrong in your buffer stage if putting after the pot spoils things.
Output impedance of a DAC analog stageHide this!Advertise here!
Analog output stage for Bufallo III dac fragoulisnaval Digital Line Level 2 6th March 2012 07:58 AM
Analog output stage for DAC (AK4584) Ekkeri Digital Line Level 3 22nd March 2009 07:37 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Analog output stage for cd sopapo Solid State 0 6th September 2006 09:17 AM
Analog Output Stage Alien8 Digital Source 6 12th March 2004 10:02 AM
