I2S and digital signal path - in-line resistors? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd May 2012, 06:14 AM   #11
Arius is offline Arius  United States
Some of the above posts are inaccurate...
We're talking about basic high speed digital design, i.e. we want the logic 0/1 to arrive at the destination (where it matters) at the right levels and at the right time.
The uni-directional (transmitter --> receiver) signal is as simple as things can get and is what I2S runs on. You worry about reflection when the wire/trace is long and/or when the signal risetime is fast (e.g. a simple reset signal from a FPGA can have issues). To help alleviate that, series termination (located at the transmittter) is the simplest form. Your PCB stackup and trace width/separation should also be design to match the impedance characteristics (e.g. 50ohms usually for single-ended, USB is 85ohms differential).
Now how do you know if your circuit is well taken care of? You look at the signals with a scope (proper probing required). You want to ensure that the signal rise/fall edges are monotonic, under/overshoot is within spec and crosstalk from adjacent signals are acceptable. The first 2 parameters are achieved by proper high speed layout techniques (use termination, proper pcb traces, minimal via transitions, no routing over plane splits, etc). The last parameter is achieved by proper pcb layer stackup design and wise routing.
Do NOT EVER put caps on digital transmission lines. Series caps are typically for AC coupling (more commonly seen with PCIe than I2S). Parallel caps can snub terminations but the danger here is that they slow down the risetime of the signal and can lead to loss of timing margin (data setup/hold).
Series termination are used successfully for far more complex stuff, e.g. SPI at 50MHz, DDR2/3 at 500MHz. Typical values are 22R-33R. I have never seen 47R series termination resistors in any embedded design. I was just at Embedded Systems Conference West in San Jose. Saw plenty of reference designs, including I2S/digital audio stuff. Nope, no 47R there.
Look up Dr Howard Johnson's books (the digital designer, not the hotel chain). Lots of good info.
For the typical hobbyist like the OP with a simple I2S circuit, I'd just put my chips as close together on the PCB as possible and call it a day. If you like to cable I2S from one board to another, then that is where you'll run into issues. Most important point for cabling I2S is to ensure adequate ground returns for every signal (e.g. you use ribbon cable, put a GND wire next to every signal, use a 2-row connector with one row being all GND pins). Consider active buffering if your cabling is long.
Hope this helps.
Old 3rd May 2012, 06:17 AM   #12
marce is offline marce  United Kingdom
These are series termination resistors, look at stuff by Howard Johnson and Eric Bogatin.
The value of the resistor has to be matched to the line impedance, generaly 50 ohm. The best way of doing this is a scope on the real layout of signal integrity simulation software. The impedance will only be +/- 20% unless controlled impedance PCB's are used. Values I have seen are usually between 47 and 100r when based on rules of thumb. When I get chance I have some scope shots showing the effects of resistor value on waveforms, both measured and simulated.
Old 3rd May 2012, 07:29 AM   #13
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by siliconray View Post
I think 47-100 is too much since the impedance of transmition line is around 50Ohm. For example,the dirving impedance of TTL is 13 Ohm, put a 37 Ohm in series will match the impedance for 50 Ohm. It's correct that the resistor should be put at the driver end.
In my opinion it's not necessary for I2S at all. Several MHz Is far from high speed digital. It really count in USB2.0 or 3.0.
I guess its been a while since youve looked at digital audio signal bandwidth. clocks are pushing 100MHz with 32/384 and up to 32/768khz PCM and then we have DXD and DSD
Old 3rd May 2012, 10:55 AM   #14
Originally Posted by kevinkr View Post
Should be placed at the source end of the I2S signal path. (Provides a terminating impedance for reflections from the driven device so they do not corrupt the transmitted signal.)
Actually... they don't "match" nothing, they just add series resistance to the transmission line to cover the native series inductance of the traces and therfore reduce the Q of the circuit.
The traces impedance is not 50 ohm (unless you make the connections with coaxial cable).
Old 3rd May 2012, 12:58 PM   #15
DF96 is offline DF96  England
If constant width, then PCB traces do form a transmission line. Transmission lines do not have to be coaxial. The impedance could be 50 ohms, or less or more. Back termination (i.e. at the sending end) is a valid technique to damp reflections while maintaining full voltage swing into a mismatched (i.e. high impedance) load. In uncritical situations the match does not have to be that good, just good enough to rapidly attenuate reflections.
Old 3rd May 2012, 01:43 PM   #16
s3tup's Avatar
1. These resistors are there for transmission line impedance matching.
These
2. These resistor values should be choosen based on source impedance of drivers and transmission line impedance.
3. There are several ways of line termination - series, paralel, thevelin and it's variations, and series-paralel.
Transmission line impedance is a rate between it's inductance and capacitance to ground per length. Inductance is usually constant thing, based on length, but width of trace won't change the inductance too much. So capacitance rules the line impedance.
Capacitance is the heigh of coductor above ground plane, and conductor's area.
So, to get certain impedance, you need to control board(dielectric) thickness and trace width. Board thicknesses are a standart values, but trace width is up to your consideration.
Trace impedances wary greatly. For example, you can't really get low (50ohm) impedance on 1.6mm board. You'll need really wide trace, as the height of conductor above ground plane is too large to create largish capacitance required. There is a trick with waveguided coplanar wave transmission line design to get it right at 1.6mm board, but it requires precise track-ground fill spacing which make the required capacitance.
For the process involved in wave transmissions inside mismatched impedance systems:
1. Mathed line - the receivers get the signal as it went out of transmitter.
2. low impedance to high impedance transition: lots of reflections on receiver end.
3. High impedance to low impedance: wave fronts get lowpassed, no reflections.
The speed of circuit is not the rate of clock or whatever. The "speed" of circuit is the slew rate of signal fronts passing in the circuit, which are fully dependant on logic families and supply voltages involved. 8ns for HC, 3-4ns for AC, and much faster for ABT and other new logic families.
You can split the transmission lines into 2 groups - short and long. The length is determined by signal slew rate (time units) and travel speed of wave in transmission line (it is slower than speed of ligt, and impedance dependant).
Imagine a "rise" transition with 10%-90% time of 4ns. Multiply it by speed, and you get length of transition.
This lenght of wave is then is being compared to your actual track length.
If your track length is 1/10 of wave length, then you don't have real transmission line. Short traces won't affect much the signal.
If your transmission line is long, then you should both terminate it, and control it's impedance.
As a side note for EMC: the lower the impedance, the less noise it will create. The slower your logic gates, the slower their slew rate, and they produce less noise.
For DIYers: Slow logics = less care of transmission line impedances could be taken.
Coaxial cables - 50 or 75ohm.
Ribbon cables - 110ohm impedance in GSGSGSG structure (G=ground, S=Signal).
Use of ribbon cables with other than GSGSGSG structure is prohibited. SSSSSSSG - is worst case, and couldn't be used in DACs.
For better understanding of trace/pcb impedances - check a nice "calculator" - Saturn PCB Toolkit - http://saturnpcb.com/pcb_toolkit.htm
Old 3rd May 2012, 02:00 PM   #17
s3tup's Avatar
IC source impedance usually is missing in datasheets. But you can calculate it yourself - usually the datasheet states the output voltage level for different (min max) load resistances. You have 2 voltages, 2 resistances. Use Ohm's law to calculate involved currents, and find the source impedance which stays constant for both cases.
Old 3rd May 2012, 02:07 PM   #18
qusp's Avatar
sure ok, but I dont think that was what was being discussed by siliconray here
which is what I replied to and i think both types of speed are under consideration here these days are they not? with the advent of CPU's, DSPs and other core type processors like Rasberry Pi and Beaglebone are being involved in digital audio more and more. Projects like the i2s/spdif fifo buffer, they are involved in the one board.
thanks for the link though, this is certainly one of those areas i'm a complete know-nothing novice
Old 3rd May 2012, 02:18 PM   #19
s3tup's Avatar
Transmission rates and transmission line impedances aren't directly related.
You can pass 500MHz data with the same bandwidth as 44kHz. Use "sine" for 500MHz and fast slew rate "square" for 44kHz.
If you have lots of reflections, then these reflection could cause different troubles as "double clocking" where the clock arrives on IC input, and the reflection arrives a bit later - the IC sees two spikes, and then clocks twice. Even for 1Hz signal you will get the same double-clocking thing.
On the opposite side of slew rate sits jitter - we want to get the slew rate of clock as fast as possible, as it determines the uncertainty during signal transition from L to H or vice versa. The faster the edge will be, the less uncertainty in time we'll get. Less jitter the noise will introduce, as it is important during transition time only. Shorter transition time = better jitter.
Old 3rd May 2012, 04:11 PM   #20
qusp's Avatar
I didnt say they were related, I only said they both apply. faster clock = less jitter seems counter-intuitive, as fast clock/slew rate will cause more ripple on the power supply/ground which given clocks (andf most other analogue mechanisms) usually have lower PSRR down low and phase noise in 1-100hz seems the most important spec. so while I understand what you are saying, I think its not that simple as one advantage may to some extent cancel the other
what resistors are in the aikido signal path jarthel Tubes / Valves 10 29th June 2006 07:33 AM
Relays in digital signal path Prune Digital Source 23 2nd July 2004 06:08 PM
Copyright 1999-2017 diyAudio
