Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd May 2012, 06:19 AM   #1
akis is offline akis  United Kingdom
Default Counting digital pulses and resetting
I have a 555 generating pulses feeding a 4029 or a 4017 which counts them. When the 4029/4017 reaches, say, 5 counts, I detect it with a couple of AND gates and then reset the 4029/4017 so it starts counting again from 0.
This works fine when the output of the divider/counter is used to drive say a 7-seg display or an LED.
However this technique of resetting still allows the count to reach number '5' even for a few milliseconds and this is undesirable. What is the proper way of counting to X and resetting at X+1 but without allowing X+1 to appear at the output ?
Old 2nd May 2012, 06:29 AM   #2
jan.didden's Avatar
Are you really seeing a few mS of '5'? I can imagine a spike of less than a microsecond, but if it's milliseconds there's something wrong.
Do you have a schematic?
jan
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 2nd May 2012, 07:06 AM   #3
Maybe not 100s of milliseconds but there is a spike at the output. As you can see the outputs will also need to drive relay switches, and I am scared that some relays receiving spikes and maybe even accidentally switch on.
Old 2nd May 2012, 07:07 AM   #4
godfrey is online now godfrey  South Africa
Maybe skip the and gates? Here's something similar for inspiration: PROPORTIONAL RADIO CONTROL by SM0VPO
edit: Oops, cross-post.
Old 2nd May 2012, 08:02 AM   #5
jan.didden's Avatar
Probably the problem is that you correctly decode the '5' but to reset the counter, you need another clock pulse and until that one comes along, the '5' is tehre.
So you should use the gate detection of '5' to reset and clock the counter at the same time. You can combine clocks with a couple of diodes.
Or maybe you should invest some time in using a microcontroller. Cheaper and simpler, but needs a learning curve.
jan
Old 2nd May 2012, 08:14 AM   #6
jan
The chip resets immediately on the '5' - here is the simulated oscilloscope output from pin '3' at the top and the clock pulse at the bottom. The intention is to count: '1', '2', '1', '2', '1' .... so when the '3' comes in the count goes back to '1' - but there is a spike that appears (necessarily) on '3'.
Maybe this spike is nothing to worry about, I am just looking for a cleaner way.
I have no experience with microcontrollers, but I have read they are programmable in assembly, and I do code in assembly (Z80, 68000 and mostly 80x86) - however it probably is a huge learning curve for me right now.
Old 2nd May 2012, 08:16 AM   #7
jan.didden's Avatar
I did my share of assembly, but that's sooo 20th century ;-)
Now adays I use Flowcode to just 'draw' the flowchart, sim it to check and let the computer worry how to convert it to a hex file and load it into the controller.
jan
Old 2nd May 2012, 08:18 AM   #8
So latch the display on the other edge of the clock pulse so the counter will reset while you're not looking. Cheesy but effective and no worse than 555 timers.
Or, take a totally different approach and use a microcontroller and do the 7 segment decoding in software where you can easily implement text in addition to digits. Of course I'm advocating mission creep but fewer packages. Or use a multicharacter display instead of discrete 7 segment units.
Old 2nd May 2012, 10:24 AM   #9
DF96 is offline DF96  England
Use a low pass filter to drive a Schmitt trigger? That will smooth away the spike. Remember, all digital circuits are merely overdriven analogue circuits so you can use analogue tricks - the circuit itself is using all sorts of analogue tricks you don't want (stray capacitance, ground bounce etc.) so why not add one you do want?
irs2092 resetting with low frequencies. nigelwright7557 Class D 84 20th February 2011 09:06 PM
Digital counter for counting to e.g 4 or 8 lykkedk Digital Source 0 17th May 2004 06:30 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
Copyright ©1999-2013 diyAudio
