how to make pcm1704x4 to output balanced signal?
Old 27th April 2012, 12:32 AM   #1
shadownee is offline shadownee  China
Default how to make pcm1704x4 to output balanced signal?
I'm making a pcm1704 dac, is there anyone can tell me how to make it output balanced signal?
Thanks.
Old 27th April 2012, 02:45 AM   #2
Ken Newton is online now Ken Newton  United States
Ken Newton's Avatar
Yes. The PCM1704 is a mono DAC, so you will need two of them per channel. Set the phase of one PCM1704 as non-inverting, and set the phase of the other PCM1704 as inverting. The PCM1704 is unique in that it allows it's absolute phase to be set via a dedicated control pin, making this all very easy to implement.
Old 27th April 2012, 02:06 PM   #3
Thank u!
I'll try it.
Old 27th April 2012, 03:47 PM   #4
Ken Newton's Avatar
As an alternative, you might want to consider the quad PCM1704 DAC module soon to be offered by AD Labs. It features balanced current outputs intended to feed I/V conversion and analg output circuits of your choice. QUAD PCM DAC (RD30) | AD LABS
Old 29th April 2012, 02:30 PM   #5
samoloko is offline samoloko  Bulgaria
any schematic ?
Is It really needed a single dac chip per phase for a balanced output dac
I have read that that Is a wrong conception
there are many balanced output dacs with a single dac chip per channel
Old 29th April 2012, 03:46 PM   #6
qusp is offline qusp  Australia
qusp's Avatar
for this dac, yes as its a mono dac chip
Old 29th April 2012, 09:09 PM   #7
Ken Newton's Avatar
Originally Posted by samoloko View Post
any schematic ?
The answers to your questions will become rather self-evident once you examine the PCM1704's datasheet.
Old 1st May 2012, 12:30 AM   #8
twest820 is offline twest820
Is it really needed a single dac chip per phase for a balanced output dac?
It is not; figure 3 in the LME49274 datasheet is a good starting point.
how to make pcm1704x4 to output balanced signal?Hide this!Advertise here!
how to make use of all dac signal outputs chokesrule Digital Line Level 9 26th February 2012 07:58 PM
Way to get a balanced signal out of a PC? ribolovec2 PC Based 3 6th January 2012 03:54 PM
balanced signal gupsta Multi-Way 13 9th May 2008 10:06 PM
Balanced Signal Levels- voltages?? lgreen Parts 5 6th April 2004 03:22 PM
Balanced Signal Through Entire Amp? G-Daddy Solid State 7 11th March 2002 08:46 PM
Copyright ©1999-2017 diyAudio
