| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 | |
#22 |
I believe I2S output fell off the pin header / multiplexer as one of the last revisions to the RPi before the first batch were manufactured and was mentioned as potentially returning later. I haven't checked up on that for a month or two now though so maybe its changed.
I haven't had a chance to play with i2s out from it yet but I have a beaglebone that I'm mucking around with in spare time (haven't had much lately). This board is a bit more expensive than raspberry pi but has some pretty good support and all schematics and pcb files are there for you if you chose. Its certainly not mega expensive though. Basically its the Ti equivalent of the raspberry pi. |
#23 |
I fully support DJNUBZ. I have been looking for a solution forever. The Hifi360.cn HF D1B is not good. I suspect the different channels can not be controlled separatly due to the device applying a Dolby prology code on your sound (whatever the source: PCM 5.1 or AC3). The Motu 896Mk3 or M-audio 2626 are possible solutions, but quite expensive. This is basically bying a truck to carry a notebook, if you see what I mean. I am sure that they sound excellent though. I dream of a USB input with 3 * SPDIF output. Someone mentionned that Creative or M-audio did something like this? Could you show me which one? Serge |
#24 |
There was a design using an STA310 decoder on here, but no one really shared any detail on their designs. There were one or two people on here that built a working design. I don't know how to program do it's not really something I could have done. The STA310 required a micro controller, and it's obsoleted I think. I'd like to be able to use a multichannel decoder and good D/A converters for each channel.
#25 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
What counts as a 'good D/A converter' to you - measurement figures or sound?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#26 |
If I were to set a standard, I would say the ODAC measures very good, sounds very good and is priced right. If I could buy 3 of them an use them to make a 5.1 surround setup I would in a heartbeat.
Here is an interesting example of a DAC made with an FPGA, I wonder if something like that could be made for a surround setup since FPGAs are so flexible. Vishay Precision Group - Foil Resistors - Case Study: Developing a Multi-Channel DAC for High-End Audio Applications |
#27 |
#28 |
#29 |
Do you have links to these boards?
#30 |
They look to be the very same boards I mention here (I give a link to a Taobao seller): 5.1 usb decoder
| Will a modern budget DAC beat a high end 1990's DAC? | daws0n | Digital Source | 3 | 9th July 2011 08:24 PM |
| Opinions on DIY DAC vs outdated high-end DD/DTS processor | vision | Digital Line Level | 0 | 27th April 2010 07:31 PM |
| Ultra High-End DAC designs for DIY? | steaxauce | Digital Line Level | 61 | 27th February 2009 06:54 PM |
| High-end DAC designs? | sidd0rs | Digital Source | 18 | 27th October 2008 04:17 PM |
