DAC: CS4398 with CS8416+CM102s
Old 29th April 2012, 11:03 PM   #21
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I'll set up a Google Docs for files so they can be saved for future access.
I'm working on a spreadsheet with current demand of the chips for comparison to actual current demand.
I powered mine up today and was not disappointed.
I think the designer actually did a pretty good job on it with relatively few areas for improvement (other than changing to better components). The SOT233 regulators are not low noise and the data sheet shows them designed for use in SCSI termination, Battery Chargers, etc. However, the use of 78/79xx pre-regulators eliminates a lot of power supply noise.
Last edited by TheGimp; 29th April 2012 at 11:23 PM. Reason: Link didn't work. I'll figure it out.
Old 30th April 2012, 12:12 AM   #22
SoNic_real_one is offline SoNic_real_one  United States
I just replaced the 100uF after the 78/79xx regs with Rubicon 1000uF. Now there is enough "umpfh" for the OpAmp stage. Will post measurements.
Old 30th April 2012, 12:36 AM   #23
TheGimp's Avatar
Someone let me know if this link works. It should show 3 files, the top and bottom pictures and the schematic.
https://docs.google.com/#owned-by-me
Old 30th April 2012, 03:59 AM   #24
Nope, not good. the link as it is, it requires to sign on and then sends me to my documents.
As for the 1000uF instead of 100uF on output of regs - the bass sounds like it should be on my headphones. Maybe for line level 100uF was OK, but for headphones definitely was needed more storage.
Old 30th April 2012, 04:20 AM   #25
TheGimp's Avatar
I guess I need to read some docs to figure out how it works.
https://docs.google.com/file/d/0B6gN...hUX3VSUzQ/edit
Lets see if this works.
By the way,
How do we go about measuring the performance of a DAC?
Wave files will play 44.1K through media player. But how to get 96KHz output from a windows pc?
I've got AudioTester which will go to 192Ks/s, but it uses the sound card for both input and output. I can measure the output of the DAC feed into the audio card with AudioTester, but it won't drive the USB output.
Old 30th April 2012, 04:26 AM   #26
That works.
I measure mine with my soundcard: E-MU1820m.
I don't have the auxiliary digital I/O and via PCI coax it cannot output 192kHz (only on ADAT). It has ballanced inputs so I have to short one of the sides to ground to input unballanced signals.
You can add those files. First two are from Lisa (ljm).
Last one is the recomended analog out stage from datasheet.
Old 30th April 2012, 01:00 PM   #27
TheGimp's Avatar
I've got the M-Audio Audiophile 192 which does support SPDIF so I should be able to test that.
MY issue is when testing USB input. What do I need under windows (XP-Pro) to drive it with to get a 92K sample rate source out of the USB port. And, what to use as the file for testing? Do I need to record test tones with the sound card set for 96K sample rate, and play them back via USB?
M-AUDIO - Audiophile 192 - High-Definition 4-In/4-Out Audio Card with Digital I/O and MIDI
I'm using AuidioTester, which supports up to 192K sample rate, but does not seem to support USB.
audioTester
Thanks for the additional data, I'll upload the files tonight. I can't access Docs from work.
I just looked at the Audio Tester site, and it looks like the latest release supports USB devices. I'll have to download the release and try it.
If that works, I only need to get some high sample rate music for testing with.
Old 30th April 2012, 11:06 PM   #28
I don't think you will able to test USB past 16bit 48kHz - that's what I did in the first post of this tread.
For WinXP you might need drivers.
Old 1st May 2012, 01:35 AM   #29
TheGimp's Avatar
Yes, the CS102S is a USB 1.0 device and does not work above 20KHz or 44.1ks/s, but I have another board that does hence the desire to be able to test to 192Ks/s. Sorry abut not making that clear.
Files are uploaded.
Old 1st May 2012, 01:56 AM   #30
On the above link, I can see only the first pdf that you added.
PS: On USB (CM102S+) works ONLY at 16/48. Doesn't have 44.1kHz capability.
DAC: CS4398 with CS8416+CM102sHide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 10:45 PM
FS Gigaworks DAC cs4398 - cs8416 - cs8421 - opa627 Upsampling apoopoo999 Swap Meet 0 31st January 2012 04:40 PM
Crystal CS4398 *2 CS8416 Parallel DAC LucasAdamson Digital Line Level 23 16th September 2011 06:51 AM
Gigaworks CS4398 CS8416 USB DAC wushuliu Swap Meet 3 31st May 2011 08:58 PM
DAC using CS8416 and CS4398 binspaul Digital Source 1 29th September 2009 12:37 PM
