| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#31 | |
Some people will apply proper silence in periods like this whereas others will simply let us listen to the acoustic. Certainly if with one CD this period is noisy and on another it is not, it implies that the noise is actually on the CD so we're not actually listening to zeros but a signal of some sort.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#32 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Nope, you'll need to read the thread a bit more carefully. This is just an experiment to demonstrate that 5th's understanding of masking is rather too simplistic. It has no direct connection with any DAC.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#33 |
Here is an example of just that happening. This is the opening of of Strauss' 4 last songs as sung by Renee Fleming.
![]() This is with 57dB of gain applied. The start is true digital silence and what follows it is the noise when the faders go up, the performance is still yet to begin. If a recording didn't have true silence put in at the start you'd get noise playing as soon as the track starts playing.
#34 |
So now I've given you my data set are you going to respond to my earlier question?
#35 |
And what question would that be? Your dataset, if by which you are meaning the audacity screen shot, looks almost identical to mine. Digital silence followed by the faders going up = recorded noise. I don't see what it is you're trying to ask.
#36 |
Post #23, my third paragraph.
#37 |
I have answered this a few times over already I feel. Yes, the noise floor on those CDs is only ~60dB below maximum amplitude.
If you are hearing noise played through the system with some CDs and then not with others then you have to think why. Now it stands to reason that the CDs that present you with no noise will have true digital zero in the data stream. Those that have noise will have something else. I suggest that you record true digital zero onto a CD and see what happens when you play it back. You could also record several tracks with noise recorded at different levels. , -90dB, -80, -70 etc and see what happens, and then also listen for when the noise becomes audible. There could be a couple of things perhaps occurring here. One is that the DAC, when fed with digital zeros, actually holds the output in a muted state so that any noise the output stage of the DAC might intrinsically produce is not heard. However when fed with something less then zero, the output is engaged and the true noise floor is revealed. Here the encoded noise is below audibility, but the DACs own intrinsic noise dominates and you hear it. If you wanted to, you could also record 20kHz sine waves onto the CD, or a sine wave of an appropriately high frequency so that you cannot hear them. The sines could be at 0dBfs -10, -20....then if you are unable to hear the tone, if the reproduction of it by the DAC is going to produce noise, then you should be able to hear the noise.
#38 |
Please explain the steps you took to determine this from the waveform I posted?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart Last edited by abraxalito; 11th April 2012 at 11:16 PM. |
#39 | ||
The 2 seconds "before" noise modulation is not happening in the DAC, is in the mixing console. DAC cannot hold that much data to anticipate for 2 seconds. Quote:
#40 | |
Of the wave-form you posted, you never mentioned if it is one of the CDs that hits you with noise as soon as the data stream starts. Regardless of if it does or doesn't, if your system really is playing back noise with some CDs and not with others, then you need to investigate exactly why this is so.
| AD1955 | tommy54 | Swap Meet | 0 | 15th August 2011 01:45 PM |
| Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 07:03 AM |
| Ad1955 Dac | skybird | Digital Source | 3 | 11th August 2008 03:13 PM |
| AD1955 audio out and I/V | matejS | Digital Source | 4 | 11th February 2008 01:14 PM |
