| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi, I did not know where else to ask this
![]() I am trying to help my son with his electronics GCSE and this is the first time I am playing with digital circuits. My problem is this: I want a device that will "flip" when I give it a pulse. It's output should be 0 to start with, then goes to 1 when I feed it a clock (on the rising edge) and stays 1 until it gets another clock at which point it goes back to 0 and stays 0 and so on. I have looked at "D type flip flop" but I cannot see how it will toggle when I simply feed it a pulse. Thanks |
#2 |
#3 |
To make D-flip-flop alternate states on clock pulses you need to tie the Q' output back to the D input.
You can do the same funtion with a J-K latch by tying its J and K input together - using those as the input.
Steerpike's Toybox |
#4 |
I used a 4027BD on the simulation and it works fine, but now I will try also the D-type flip flop as suggested
Edit : Yes a 4013 with Q' connected to D works as well ! Mnay thanks Last edited by akis; 8th April 2012 at 08:14 PM. |
| Minimal toggle flip flop with discrete transistors required | heater | Parts | 7 | 7th February 2012 06:09 PM |
| Tapedeck Controls don't want to latch | bulgin | Analogue Source | 1 | 5th April 2008 08:05 PM |
| Remove push latch on Neutrik B series sockets | fmak | Parts | 0 | 2nd April 2007 11:17 AM |
| t-latch in LTSpice | zilog | Parts | 0 | 13th January 2007 12:51 AM |
