| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
is choosing a less facetious title...
its still a bit muddy in this thread
i2c is the 2 wire serial communications protocol used to program and control the device. I2s or IIs for short is the audio data format which has several incarnations depending on the dac being used generally in PCM, the most common format this days it will contain Master clock (MCLK) Bit Clock (BCK) Serial Data (SDATA) Ground (GND) |
#12 | |
USB 1.1 (UAC 1.12 i think) will allow 96khz UAC2 is native in mac OS and has been for years Last edited by qusp; 5th April 2012 at 10:41 AM. |
#13 |
UAC2 is limited to certain devices only. That im my view, is equal to providing separated drivers...
MS does not have native drivers capable of more that 16/48. TI does not list their devices as capable of more either. Last edited by SoNic_real_one; 5th April 2012 at 10:52 AM. |
#14 |
no, its native for any operating system that complies with the standard just like UAC1, that being Mac OS and linux, just because windows has been dragging its feet keeping with the standard does not mean its not a native standard. the devices are limited to 16/48 not the standard any UAC2 standard device (and a few others) that is capable of 16/96, will do so even on a host that is only UAC 1.12.
any native standard requires that the code be part of the operating system to work, it just happens that win is useless in this regard, so useless its baffling also i knew i was forgetting one above MCLK BCK LRCK or word clock SDATA GND Last edited by qusp; 5th April 2012 at 01:12 PM. |
#15 | |
Now I am not totally apposed to learning this (although my interest in this hobby does not lie with USB/DRIVER programming) but I have had very sparse luck when looking around for code/examples or anything that could set him in the correct direction. Last edited by kevloon; 5th April 2012 at 04:11 PM. |
#16 | |
Use the PCM2706... There is nothing to program, it just works!
I can concot a "standard" tommorow and claim that MS "doesn't follow it". But if nobody else (but me) follows it, it is useless. Last edited by SoNic_real_one; 5th April 2012 at 04:41 PM. |
#17 | |
It doesn't do 24/96 but do you really want all the extra hassle just to extend the frequency range beyond 22KHz? Only bats will be able to hear that!
Music is art - Audio is psychoacoustics & engineering |
#18 | |
#19 |
What UAC1 capable device is then capable of more than that? Not UAC2...
If you don't have any, than the UAC1 standard is useless. 10 years too late. |
#20 |
The Tenor TE7022L is what you want, but Galaxy Far East Corp will only sell to OEM's willing to buying thousands of pieces.
GALAXY FAR EAST CORP. http://www.gfec.com.tw/documents/101...2SL_PB-v21.pdf
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
| dig out (S/P-DIF, DOBM) for Philips CD100 and Revox B225 (only SAA7000 data out) | tiefbassuebertr | Digital Source | 8 | 17th March 2012 09:16 PM |
| Which CD-Players offers Dig-Inputs to use the internal DAC for DAB/DVB Radio ? | tiefbassuebertr | Digital Source | 8 | 14th June 2010 10:46 AM |
| Optimizing interface between decoders, dig. filters & DAC IC's | hollowman | Digital Line Level | 3 | 17th July 2009 07:00 AM |
| USB powered NOS USB DAC with built-in headphone amp | dsavitsk | Digital Source | 15 | 10th August 2006 06:11 AM |
| Regulator IC Data - LAS19U | JDeV | Parts | 9 | 24th May 2003 10:01 AM |
