buffer SPDIF input stage for ESS9018
Old 19th March 2012, 08:52 AM   #31
jonclancy is offline jonclancy  United Kingdom
Originally Posted by merlin el mago View Post
Thank you stormsonic, now I see is for AES/EBU balanced signal not for S/PDIF signal, also I take note to use U = unbuffered version.
Jocko's input was designed for the CS8412 / 8414. Those devices have a balanced SPDIF input into the RS422 receiver in the device.
RXP (Pin 9)
RXN (Pin 10)
The component values are calculated exactly for this application, too.
As an aside, I have tried it out on a WM8804 receiver (unbalanced SPDIF input) and it works, but I know it wasn't optimised.
John Linsley Hood Ripple Eater GB Part One made 729 for Cancer Research UK. Thanks for your support!!!
Old 19th March 2012, 01:13 PM   #32
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by JensH View Post
You could try to modify it as I suggested in post #15. The impedance is correct for SPDIF.
For AES/EBU you would need a higher impedance (110ohm).
As I wrote, the modification will give you twice as much signal. And that is at the buffer input, so it will make the buffer less sensitive to noise. The output will still be from 0 to the supply voltage (5V in this case).
RXP (Pin 9)
RXN (Pin 10)
Thank you guys
Old 23rd August 2015, 08:43 PM   #33
lauda is offline lauda  United States
lauda's Avatar
Reviving this thread because I was having dropout issues on a ES9018K2M-based prototype. In my case, the primary and possibly only antagonist was electromagnetic interference. Since using shielded cable for the 4" connection from the optical SPDIF receiver and the chip inputs and putting the thing in a proper enclosure, I haven't experienced any dropouts--and that's testing with a mains-powered drill about an inch from the enclosure.
I need to do more thorough testing to see if it completely resolves the issue, but I thought I would mention it ASAP in case it helps someone.
buffer SPDIF input stage for ESS9018Hide this!Advertise here!
Need input on Buffer stage to use in Preamp.. Adrculda Tubes / Valves 22 9th August 2012 02:55 PM
SPDIF S/P-DIF DOBM resp. Digital Input Selector include USB-SPDIF Converter tiefbassuebertr Digital Source 6 21st February 2012 09:00 PM
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 03:17 AM
connecting input directly to ucd, no input buffer mazurek Class D 20 19th July 2006 04:32 PM
what do you think of my input buffer stage mazurek Parts 6 6th April 2006 04:03 PM
