Go Back   Home > Forums > Source & Line > Digital Line Level
Old 13th March 2012, 06:40 PM   #21
Dropouts with SPDIF with ES9018 can (my opinion based on experience) be caused by register programming (not optional) of the ES9018,
or inadequate PSU / mains noise.
I do not have any problems at all even if I only use a digital pulse transformer directly connected to the ES9018 without any other components - except the 75 ohm termination resistor.
Your problem could be as simple as you are using SPDIF and have PCM word clock, PCM bit clock or PCM data connected and receiving ...
Old 13th March 2012, 07:01 PM   #22
merlin el mago's Avatar
or inadequate PSU / mains noise.Can be fixed the register programming? I think not inadequate PSU / mains noise: I use R-Core tx + Salas BiB regulator 5,25Vout 681mA, TP recommend 5,25V 490mA
Your problem could be as simple as you are using SPDIF and have PCM word clock, PCM bit clock or PCM data connected and receiving ... Could you elaborate and tell me how can solve/fix the isue?
Answered in red.
BII DIP switch settings are:
SW1
1,2,3 OFF
4 ON
5,6,7,8 OFF
SW2
1 ON
2,3,4,5,6,7 OFF
8 ON
Old 13th March 2012, 07:12 PM   #23
SW1
1,2,3 OFF
4 ON
5,6,7,8 OFF
SW2
1 ON
2,3,4,5,6,7 OFF
8 ON
I have no BII competence in respect of switch settings or programming.
If you are running both SPDIF and PCM signals simultaneously to the ES9018 and that is the problem - there is maybe only two ways to cure this.
1. Disconnect the PCM signals when using SPDIF.
2. Change the programming for the ES9018 (I cannot help with this).
For option 2 you could contact the vendor of you DAC.
Old 13th March 2012, 07:17 PM   #24
Sorry is BIII. Do you want that I change IIR bandwith to DSD 50K, 60k or 70k?
Old 13th March 2012, 08:01 PM   #25
I increased the CCS current to 845mA to see what's happen.
Old 14th March 2012, 10:30 AM   #26
stormsonic's Avatar
@merlin
Go HERE and start reading. Or skip to the last page, where nice guy from Romania is willing to share pcb files.
And please use 74HCU04, where U = unbuffered.
Old 14th March 2012, 11:59 AM   #27
Thank you stormsonic, now I see is for AES/EBU balanced signal not for S/PDIF signal, also I take note to use U = unbuffered version.
Old 14th March 2012, 12:13 PM   #28
stormsonic's Avatar
...not for S/PDIF?
Old 14th March 2012, 01:52 PM   #29
Have I to use only half schematic for unbalanced S/PDIF signals right?
Old 14th March 2012, 04:10 PM   #30
JensH is offline JensH  Denmark
You could try to modify it as I suggested in post #15. The impedance is correct for SPDIF.
For AES/EBU you would need a higher impedance (110ohm).
As I wrote, the modification will give you twice as much signal. And that is at the buffer input, so it will make the buffer less sensitive to noise. The output will still be from 0 to the supply voltage (5V in this case).
Need input on Buffer stage to use in Preamp.. Adrculda Tubes / Valves 22 9th August 2012 01:55 PM
SPDIF S/P-DIF DOBM resp. Digital Input Selector include USB-SPDIF Converter tiefbassuebertr Digital Source 6 21st February 2012 08:00 PM
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 02:17 AM
connecting input directly to ucd, no input buffer mazurek Class D 20 19th July 2006 03:32 PM
what do you think of my input buffer stage mazurek Parts 6 6th April 2006 03:03 PM
Copyright ©1999-2013 diyAudio
